Front running lights
  • Kawboy74
  • Kawboy74's Avatar Topic Author
22 Jan 2013 00:37
#568586
In the interest of safety I have converted my front signals on'74 Z1 to dual filament bulbs with an inexpensive plug conversion kit. For some reason this past summer I lost my low beam at dusk and after changing over to high beam until I got to an auto parts outlet, it went on me about a half hour later leaving me with no lights at the front end , only taillights and brake. I have a reg/rect combo unit that I installed (from Z1 Ent.)with the rebuild to avoid charging issues as well as a complete new harness. My question is this; there is a brown double ended connector doing nothing in my headlight bucket that from my factory wiring diagram looks to be a switched power lead that I could use for the running side of the bulb. Diagram shows a std. bulb to be 23 watts for signals and I found a 1034 bulb that is marked 12V23/ 8F . Not being an electrical genius, does the lettering refer to 23 watts as the flasher with 8 watts as the running lights or the other way around? I would think you would want 8 watts to be the running lights with 23 watts for flashing which would override the brightness when signalling! It is easy to figure out which lug is the brighter one on the bulb and then I can orient the wiring in the headlight accordingly.
Any help would be greatly appreciated guys.
1974 Z1A As original as I could get it
'88 ZX750R braided lines, mostly original
KZ1000 project on the bench
Burlington,Ontario,Canada
  • rstnick
  • rstnick's Avatar
Re: Front running lights
22 Jan 2013 00:47 - 22 Jan 2013 20:03
#568589
Yeah David, buy yourself a KZ650 as most of them came with front running lights.
I wired my rears to stay on too some years back, but lost that when I switched signals over the years.
Not really sure on your question, but I do believe your right.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
Last edit: 22 Jan 2013 20:03 by rstnick.
  • Kawboy74
22 Jan 2013 00:53
#568592
Yea Rick, a 650 would be easier but garage is getting kind of full now and dollars are accounted for as you know.
Can't wait til spring to hook up down at Leslie St. again with all the vagrants.
David
  • rstnick
  • rstnick's Avatar
22 Jan 2013 20:02
#568704
Yes, looking forward to riding season again.
I hear you on space and money.
Just bought another 650, which gives me 4.
Oh, and it's Rob.
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
  • bountyhunter
  • bountyhunter's Avatar
23 Jan 2013 00:56
#568762
Kawboy74 wrote: In the interest of safety I have converted my front signals on'74 Z1 to dual filament bulbs with an inexpensive plug conversion kit. For some reason this past summer I lost my low beam at dusk and after changing over to high beam until I got to an auto parts outlet, it went on me about a half hour later leaving me with no lights at the front end , only taillights and brake. I have a reg/rect combo unit that I installed (from Z1 Ent.)with the rebuild to avoid charging issues as well as a complete new harness. My question is this; there is a brown double ended connector doing nothing in my headlight bucket that from my factory wiring diagram looks to be a switched power lead that I could use for the running side of the bulb. Diagram shows a std. bulb to be 23 watts for signals and I found a 1034 bulb that is marked 12V23/ 8F . Not being an electrical genius, does the lettering refer to 23 watts as the flasher with 8 watts as the running lights or the other way around?
23W for the flasher, 8W for the running light.
Kawboy74 wrote: It is easy to figure out which lug is the brighter one on the bulb and then I can orient the wiring in the headlight accordingly.
If you have a decent Ohm meter that can measure under 10 Ohms, the higher watt filament is the lower Ohms.
