Worth Upgrading from Points to Electronic Ignition
  • alparmer
  • alparmer's Avatar Topic Author
20 Jan 2013 19:50 - 20 Jan 2013 19:50
#568345
I've upgrade old cars in the past to electronic ignition since it's painless. Is it worth upgrading the KZ? It's about 130 bucks to do so with a brand called Dyna S.
Stock '78 KZ650 SR
Last edit: 20 Jan 2013 19:50 by alparmer.
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
Re: Worth Upgrading from Points to Electronic Ignition
20 Jan 2013 19:52
#568346
yes....do it.... B)
  • trianglelaguna
  • trianglelaguna's Avatar
20 Jan 2013 20:00
#568348
the dyna is easy....folks here can trouble shoot any swap probs you might hit...it is very easy to switch and in theory you set it with a timing gun and ...never have to mess with it ever...check here with members on wether your coils work with it..some stock kawasaki coils will/can fry at some point with the dyna set ups....members here with 650 info can better answer this point...most folks run a dyna s with dyna coils and auto store wires or some type of wire and cap with dyna coils
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • Old Man Rock
  • Old Man Rock's Avatar
20 Jan 2013 20:24
#568351
with out a doubt.... ;)
Incase electrical ain't your gig... Easy to follow Installation guide....
Dyna S Installation Guide
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • OKC_Kent
  • OKC_Kent's Avatar
20 Jan 2013 22:54
#568396
You also can upgrade using the electronic ignition parts from a newer KZ model. I did that to my 650, using a system from an early 80's 750. It might have cost me $75 buying the parts off ebay.
Have fun riding instead of setting points and timing, I sure have!
Oklahoma City, OK
78 KZ650 B2 82,000+ miles
  • baldy110
  • baldy110's Avatar
21 Jan 2013 15:33 - 21 Jan 2013 15:35
#568517
OKC_Kent wrote: You also can upgrade using the electronic ignition parts from a newer KZ model. I did that to my 650, using a system from an early 80's 750. It might have cost me $75 buying the parts off ebay.
You can do the above if your on a really tight budget but I have a hard time trusting older electrnics that are exposed to heat and vibration for over 30 years. If you can afford it go with the Dyna S.
Last edit: 21 Jan 2013 15:35 by baldy110.
  • rstnick
  • rstnick's Avatar
21 Jan 2013 21:59
#568564
I am also useing an electronic ignition from a newer model KZ.
Only did it because at the time I could not afford the Dyna, again.
I had a Dyna S fry on me.
Went back to points for a while.
I found KZ electronic bits at a reasonable cost, some years back, before the rise in current prices of all things on ebay.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
  • steell
  • steell's Avatar
22 Jan 2013 01:31
#568599
Keep in mind, if you give up points for electronic ignition, it's your fault that the bike won't start after experiencing the EMP from a nuclear explosion. :P
  • bluej58
  • bluej58's Avatar
22 Jan 2013 09:37
#568627
steell wrote: Keep in mind, if you give up points for electronic ignition, it's your fault that the bike won't start after experiencing the EMP from a nuclear explosion. :P
Good point ;)
JD
78 KZ1000 A2A
  • turboking
  • turboking's Avatar
22 Jan 2013 10:56
#568638
No eBay APP ID and/or Cert ID defined in Kunena configurationcheapest price I have found on e bay...
E bay NEW dyna S for 650 kawasaki $122.63 with free ship.
Note: must use 3.0 ohm coils
1 year warranty
No affiliation with e bay or seller
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
  • RonKZ650
  • RonKZ650's Avatar
23 Jan 2013 01:21
#568766
Dyna-S works great. Uses more power than the stock system, but no problem. Stock coils work fine. I don't even know or care the ohms of the stock coils, but they work fine with the Dyna. My old 78 KZ650 has over 150,000 on the Dyna setup with stock coils.
23 Jan 2013 10:33 - 23 Jan 2013 10:33
#568811
RonKZ650 wrote: Dyna-S works great. Uses more power than the stock system, but no problem. Stock coils work fine. I don't even know or care the ohms of the stock coils, but they work fine with the Dyna. My old 78 KZ650 has over 150,000 on the Dyna setup with stock coils.
I'd say that would qualify as a pretty good long term test of the Dyna and the stock coils! Ed
Last edit: 23 Jan 2013 10:33 by 650ed.
