Ign advance plate(s)
- THR
08 Jan 2013 18:00
Looking at ign advance plates and found there's one for canada (21148-1006) and one for USA (21148-1009). Does someone know the difference between the two? Difference advance curves?
These are from a 80 KZ1000 A3A.
Baffeled.
Baffeled.
79 KZ 1000 MKII
- DoubleDub
Re: Ign advance plate(s)
08 Jan 2013 18:06
The advance probably has a slight different amount of advance and timing between the two due to EPA regulations. Just a guess, though. Either advancer should work - I doubt their differences are very substantial.
- loudhvx
08 Jan 2013 19:43
If you can see them, maybe one is adjustable and one is not. Look at the mounting holes. In the U.S. they are just holes, but maybe the Canadian ones have slots.
...just a guess
...just a guess
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- DoubleDub
08 Jan 2013 19:52 - 08 Jan 2013 19:55
The part numbers he is giving are for the advance mechanism, not the points/ignition plates.
www.ronayers.com/ProductDetails/N/687/SKU/347437
Last edit: 08 Jan 2013 19:55 by DoubleDub.
- loudhvx
08 Jan 2013 19:54
Ahh, Ok.
1981 KZ550 D1 gpz.
Other links.
Other links.
