Aftermarket Tail light
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
Re: Aftermarket Tail light
04 Jan 2013 11:07 - 08 May 2013 00:22
#565815
Last edit: 08 May 2013 00:22 by 4TheKZ1000.
  • tachrev
  • tachrev's Avatar
  • Rubber Side Goes Down
04 Jan 2013 13:51
#565833
Great, thanks!
I have an aftermarket tail light on mine now, but I am pretty sure it is going to fail inspection.
Must have 8 sq inches of surface area to pass here...or at least look stock enough that they don't hassle you.
Build Thread
The following user(s) said Thank You: 4TheKZ1000
  • baldy110
  • baldy110's Avatar
04 Jan 2013 14:19 - 04 Jan 2013 14:20
#565841
My ELR clone has the same tail light as your 550. I cut and welded the rear subframe to allow the tail light to sit further in and flush with the rear cover. I like the look of the stock tail light as long as it's not sticking out.
Last edit: 04 Jan 2013 14:20 by baldy110.
  • 4TheKZ1000
04 Jan 2013 14:27
#565843
That looks great....real nice fab work....big improvment.... B) B)
  • bountyhunter
  • bountyhunter's Avatar
04 Jan 2013 17:56
#565867
No turn signals will get you written up around here.
  • 4TheKZ1000
04 Jan 2013 18:48
#565873
bountyhunter wrote: No turn signals will get you written up around here.
Not if they cant catch ya....... :woohoo: :woohoo: :woohoo: :woohoo: :woohoo: :woohoo: :woohoo: :woohoo:
  • baldy110
  • baldy110's Avatar
04 Jan 2013 21:14
#565908
It has turn signals. That light came with two 1157 bulbs. I used diodes and soldered them into the wiring harness so I have right and left turn signals, stop light and running light all from the stock tail lamp.
  • 4TheKZ1000
04 Jan 2013 21:21
#565909
baldy110 wrote: It has turn signals. That light came with two 1157 bulbs. I used diodes and soldered them into the wiring harness so I have right and left turn signals, stop light and running light all from the stock tail lamp.
Smooth..... B) B) B) B)
  • bountyhunter
04 Jan 2013 23:57 - 05 Jan 2013 00:02
#565929
If the turn signals are inside the tail light, they are illegal by NHTSA requirement as well as most state laws. The center-to-center distance between the centers of the turn signal's lense has to be at least nine inches. Most "integrated" rear tail lamp assemblies do not comply.
Last edit: 05 Jan 2013 00:02 by bountyhunter.
  • baldy110
  • baldy110's Avatar
05 Jan 2013 00:43 - 05 Jan 2013 00:45
#565939
Ya, and so is speeding and we all know no one does that, right.
Last edit: 05 Jan 2013 00:45 by baldy110.
  • bountyhunter
05 Jan 2013 16:46 - 05 Jan 2013 16:50
#565991
baldy110 wrote: Ya, and so is speeding and we all know no one does that, right.
It was an FYI. Out here, they inspect bikes when you go to sell them and having illegal lights will fail. Cops also look for excuses to pull people over. Just pointing out that before you put a bunch of work into mounting a new light, you might want to see if it's legal where you are.
Last edit: 05 Jan 2013 16:50 by bountyhunter.
  • baldy110
  • baldy110's Avatar
06 Jan 2013 01:29
#566045
No inspections where I live.
