help help help, wierd spark problem
  • TaborCT
  • TaborCT's Avatar Topic Author
03 Jan 2013 13:32
#565690
ok so i have a 77 kz1000. dont know much about it. traded i guy a 390ci for it and the bike wasn't running. cleaned the carbs and it fired up. came out to the shop a week later and it will backfire rarely but wont start. carbs are fine but the plugs have a continuous spark. Not turning the motor over and just laying the plug on the motor or frame so it grounds and it starts sparking like the 4th of july. it does have the dyna ignition and dyna coils. my bud and i are confused and about the rewire the whole thing if we cant figure it out.
Not all men are created equal. Thats why we can handle a KZ!
  • steell
  • steell's Avatar
Re: help help help, wierd spark problem
03 Jan 2013 13:59
#565693
Never seen that before, but the only way that could happen is something interrupting either power or ground at a rapid rate. Probably the Dyna, not likely to be anything else.
  • MFolks
  • MFolks's Avatar
03 Jan 2013 16:48
#565727
If it were me, I'd contact Dyna, and ask their thoughts about the problem:
www.dynaonline.com/skins/Default.aspx
  • trianglelaguna
  • trianglelaguna's Avatar
03 Jan 2013 18:37
#565755
pull the fuse or unhook the battery ...take timing cover off and turn the motor over by hand...or kick start iot a few times with the battery unhooked...hook it back up see wtf
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • TaborCT
27 Feb 2013 02:22
#574359
thx for the info. got ahold of dyna and they said its a failsafe built into their system. when its on a batter charger it wll throw out any extra voltage or charge out the plugs. so since i had a bad batter that was 11 years old and sat that long.... it was just going straight threw.
  • donthaveakawman
  • donthaveakawman's Avatar
27 Feb 2013 02:40
#574362
TaborCT wrote: continuous spark. Not turning the motor over
see if the points are stuck would be my best try.
  • Old Man Rock
  • Old Man Rock's Avatar
27 Feb 2013 11:06
#574399
What points.... :blink:
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • martin_csr
  • martin_csr's Avatar
27 Feb 2013 12:38 - 27 Feb 2013 17:48
#574410
TaborCT wrote: thx for the info. got ahold of dyna and they said its a failsafe built into their system. when its on a batter charger it wll throw out any extra voltage or charge out the plugs. so since i had a bad batter that was 11 years old and sat that long.... it was just going straight threw.
A handy tool to have is a digital multimeter. VC97 = good, inexpensive.
The bike needs a good battery to run right. Don't assume a new or well maintained battery is good.
A test I do regularly, once or twice a month:
Charge the battery, then disconnect the charger. Check the voltage: it should be at least 12.6 VDC, but a good battery will be higher: ~13.1 VDC or so. Turn on the headlight high beam (engine off): the voltage will drop. A good battery will drop to ~12.2 volts but ~11.85 is okay. If it drops to ~11 VDC, the battery may need replacing. If it drops to ~10 VDC the battery is shot. The high beam test removes the surface charge & gives a better indication of the deep charge or something like that. The voltage numbers are what I use; there may be a more accurate chart on the internet.
Last edit: 27 Feb 2013 17:48 by martin_csr.
27 Feb 2013 13:01 - 27 Feb 2013 13:01
#574412
Dyna sells ignition systems. You may want to ask them how the bike's ignition system can protect the bike's charging system? I believe that is impossible. Ed
Last edit: 27 Feb 2013 13:01 by 650ed.
