How to test a flasher relay
- X_Saint
11 Dec 2012 02:08
My 82 kz750's turn signals turn on but won't blink. How can I test it to make sure it's bad. I have a multimeter so I can try to ohm it out or what is something else I can do because I'm not sure the reading I am looking for. Thanks
- donthaveakawman
Re: How to test a flasher relay
11 Dec 2012 02:33
got the same problem with my flashers. it all started with the horn that stopped working. then I took apart the blinker switch to try to figure it out and now the flashers don't work.
- wireman
11 Dec 2012 10:03
Plug it in under the dash of your car and try it
- X_Saint
11 Dec 2012 11:22
Yah my horn also hasn't worked since I bought it. So I'm not sure if they are linked to the same problem or what's going on.
