Firing order
- wagonmaster69
- 78 KZ1000A2 / 82 KZ1100 Spectre
Firing order
03 Dec 2012 22:28
Just wondering the firing order on the fours are 1,4-2,3 does that mean that 1 and 4, and 2 and 3 fire at the same time?
The following user(s) said Thank You: Zephy 750
- taildragger1197
Re: Firing order
03 Dec 2012 22:35
That should be 1-2-4-3
Union City, Tennessee
1979 KZ1000 LTD B3
1979 KZ1000(1260)LTD S/G Pro ET
1993 ZX11 D1 Ninja
1979 KZ1000 LTD B3
1993 ZX11 D1 Ninja
- MFolks
Re: Firing order
03 Dec 2012 22:37
Yep, a "Wasted Spark" that fires on the exhaust stroke. Many 4's do this.
- 4TheKZ1000
Re: Firing order
03 Dec 2012 22:46 - 03 Dec 2012 22:49wagonmaster69 wrote: Just wondering the firing order on the fours are 1,4-2,3 does that mean that 1 and 4, and 2 and 3 fire at the same time?
As you can see 1 and 4 are in the same position as is 2 and 3. I do beleive they fire two at a time.
Attachment KGrHqJpE8VlcdTvpBPLDnYyhg60_1.jpg not found
Last edit: 03 Dec 2012 22:49 by 4TheKZ1000.
- wagonmaster69
Re: Firing order
03 Dec 2012 22:47
So they do or they don't fire at the same time :huh:
The "Wasted Spark" term I haven't heard that be for.
- 4TheKZ1000
Re: Firing order
03 Dec 2012 22:52 - 04 Dec 2012 01:35wagonmaster69 wrote: So they do or they don't fire at the same time :huh:
one coil fires both plugs at once one cyclinder on compression and one cyclinder on exhaust.
since it fires on exhaust its considered wasted
To go though complete cycle of firing all four cyclinders once...... you have the spark plugs firing 8 times. 2 times each.
Last edit: 04 Dec 2012 01:35 by 4TheKZ1000.
- wagonmaster69
Re: Firing order
03 Dec 2012 23:14That what I was wondering about the coils do fire both at the same time.4TheKZ1000 wrote:wagonmaster69 wrote: So they do or they don't fire at the same time :huh:
To go though complete cycle of firing all four cyclinders once you have the spark plugs firing 8 times. 2 times each.
I was always worried about the plug wires and coils and how to wire them up.
- 4TheKZ1000
- wagonmaster69
Re: Firing order
04 Dec 2012 00:09
My 82 KZ1100 has electronic ignition I think
Re: Firing order
04 Dec 2012 01:21
Pistons in cylinders #1 and #4 rise and fall together.
Pistons in cylinders #2 and #3 rise and fall together.
When 1-4 are at top, 2-3 are at bottom.
When pistons 1-4 are approaching top, one is on compression stroke, and the other is on exhaust stroke.
The dual wire coil fires once with each crankshaft revolution, at which time it sparks both cylinders 1 and 4.
Whichever 1 or 4 that needs the spark will then combust (compression stroke > power stroke).
Whichever 1 or 4 that doesn't need the spark (exhaust stroke > intake stroke) gets the spark anyway (wasted spark).
Same thing is happening with the other coil on cylinders #2 and #3.
This design allows the two coils to spark 4 cylinders.
Re: Firing order
04 Dec 2012 01:28 - 04 Dec 2012 01:29This illustrates the firing order, but doesn't show the wasted spark in the other cylinder with piston at the top (green color).
Last edit: 04 Dec 2012 01:29 by Patton.
- Old Man Rock
Re: Firing order
04 Dec 2012 08:39
LUV that GIF Patton, can't explain it any better than that.....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
