IC Igniter wiring?
  • 750steve
  • 750steve's Avatar Topic Author
IC Igniter wiring?
24 Nov 2012 08:58
#559840
If doing a fresh rewire does the IC igniter need a live feed when the ignition is turned on or is it wired that it only gets current wnen the starter button is pushed?
Bike in question is a Zephyr 750 but im sure that question will relate to any bike. I've looked at a GPz750 wiring diagrem & im unclear hence the question.
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
Re: IC Igniter wiring?
24 Nov 2012 15:16
#559872
Steve, It is my understanding that power is fed from the keyed ignition switch to the kill switch, which when set to on passes power to one of the start button leads. This same lead passes power to the coils and the IC igniter. So power is passed to the IC igniter when the kill switch is set to on. The IC igniter has a ground of its own and the plugs ground the coils so the circuit is complete.
The other side (lead) of the start button passes to the clutch lockout and or the kickstand lockout and then to the starter relay to turn the starter motor. Again the relay has its own ground and the circuit is complete. The starter button is just a switch that passes power from the keyed ignition switch via the kill switch to starter relay and the starter.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
  • loudhvx
  • loudhvx's Avatar
24 Nov 2012 15:33
#559875
Yes, basically anytime the coils have 12v, the igniter gets 12v as well.
The igniter does not use much power, and if the crank is not turning, the coils won't have any current through them.
  • 750steve
26 Nov 2012 11:05
#560116
Thanks guys! Trying to help someone else so this isn't for me. He's installing a Zephyr 750 engine into his bobber which had the 650 engine running points. Im not farmiliar with the electronic setup.
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
