stator or spark plugs?
  • donthaveakawman
  • donthaveakawman's Avatar Topic Author
15 Nov 2012 17:48
#558508
When i was riding my kz750 h1 last night after about an hour and a half, i decided it was getting cold and time to head home.
I was a little concerned about the operating temperature of the engine, so i reached down and put my gloved hand near the block. Luke warm, so i downshifted and put my gloved hand(thinsulate gloves) on the block, and i am pretty sure there was a good bunch of electricity going through my hand(my inexperience would tell me it was ac not dc). I got home turned it off and cleaned up the ground wire and oiled the spark plug rotor springs. Now what? :(
Re: stator or spark plugs?
15 Nov 2012 21:16
#558540
Would suspect high tension leakage, and consider new spark plug wires. Such as the Dyna solid core version listed at Z1 Enterprises.
Good Fortune! :)
  • donthaveakawman
15 Nov 2012 22:21 - 15 Nov 2012 22:22
#558553
yes, I know those are crappy, i replaced them last year when i got zapped on the clutch handle. now it appears when i touched the cooling fins on the cylinder block underneath the cylinder head i got zapped. on the left side above the charging deal.
Last edit: 15 Nov 2012 22:22 by donthaveakawman.
  • donthaveakawman
16 Nov 2012 06:17
#558604
Maybe it is the rectifier or maybe i am imagining it, and it's actually is " The Carpal Tunnel Syndrome" (with an echo for effect)
  • donthaveakawman
16 Nov 2012 17:31
#558682
went out yesterday again, but first i checked the voltage it was just under 15v at the battery while running. hmm.
