i got a 82 kz750 twin and i need help
  • shortyo92
  • shortyo92's Avatar Topic Author
12 Nov 2012 21:37
#558129
i got a 82 kz750 twin and i need help i bought it apart and im trying to put the wiring back together and im not sure how it goes and i think i plugged it up right we tryed kicking it to see if there was fire but we got no spark were should i go from here
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
Re: i got a 82 kz750 twin and i need help
12 Nov 2012 21:54 - 12 Nov 2012 21:56
#558132
Welcome to the forum.
I would get a correct manual for the bike and study it....you need to learn this stuff. I read mine front to back dozens of times.....no easy way around electrical problems.... :dry:
Last edit: 12 Nov 2012 21:56 by 4TheKZ1000.
  • shortyo92
12 Nov 2012 22:03
#558134
Were could I get one at
  • 4TheKZ1000
12 Nov 2012 22:06 - 12 Nov 2012 22:10
#558136
look up at right hand corner. find filebase....click and go to 1982 and click...scroll down to your model and open. will have wiring diagram.
You can get manual off ebay I would think....or download one.
Last edit: 12 Nov 2012 22:10 by 4TheKZ1000.
  • shortyo92
12 Nov 2012 22:13
#558138
Ok thanks but how do I know what model I got all I know is its a kz750 twin
  • Motor Head
  • Motor Head's Avatar
12 Nov 2012 22:19
#558139
82 KZ750 Twin is a M1 Model
www.kzrider.com/filebase/cat_view/102-19...4-kawasaki-kz-750-m1
See how you go, and post if you need help.
  • 4TheKZ1000
12 Nov 2012 22:20
#558140
post your engine and frame number. I should be able to lookup for you.
  • martin_csr
  • martin_csr's Avatar
13 Nov 2012 10:06 - 23 Jan 2013 12:33
#558180
An 82 Twin should be the M1 CSR. When getting a manual, be sure it's for a 750-Twin. Kawasaki factory service manuals have a model application chart on the back cover, so make sure yours is listed.
Last edit: 23 Jan 2013 12:33 by martin_csr.
  • tjgonz
  • tjgonz's Avatar
13 Nov 2012 22:01
#558250
I hear you bro, Same exact bike.
Had her running & took her apart to fix her up then wiring didnt work the same after.
Its been a difficult month of check, study & redo wiring.
Finally finished a brand new harness I had to make & still same problem.
I have faith but it aint easy, the M1 diagram is correct for your bike.
Study it as much as you can, my only problem now is ground wire from voltage regulator shorts when I hook it to ground. Best wishes bro, we'll be on the road soon!
