can someone point me to coil and plug wiring
  • nobody
  • nobody's Avatar Topic Author
08 Nov 2012 02:23
#557473
hi and thanks .my book isn't very good .need help wiring coils plug wires .did not turn up any thing in search box .any help would be nice thanks
Attachment kzgrabbergreennumtwo011.jpg not found
  • MFolks
  • MFolks's Avatar
Re: can someone point me to coil and plug wiring
08 Nov 2012 02:49
#557475
What year and model of bike do you have? Anyway, here's info on how the ignition coils and sparkplugs are wired for several models, keep in mind the K/GPz 550's,650's, 700's,and 750's are wired differently from the Z1's,Kz900's,Kz1000's and Kz/GPz 1100's:
Ignition Coil Primary And Secondary Wiring
Ignition coils on the 80’s Kz1000,Kz1100’s and Gpz1100’s are wired the same, that is as you sit on the bike, the LEFT ignition coil primary(small wires) are two wires, RED and BLACK. The secondary (or sparkplug wires) go to #1 and #4 sparkplugs(your primary wiring may be different).
Read carefully, as the 550’s, 650’s, 700’s & 750’s are backwards to what is listed for the bigger 4’s.
The cylinders are numbered left to right as you sit on the seat; #1,#2,#3, and #4.
For the RIGHT ignition coil, the primary wires, again are two wires, RED and GREEN, with the secondary going to #2 and #3.
The RED wire gets it’s voltage from the run/stop switch on the right handlebar switch pod. Your primary wiring may have a different color.
The BLACK and GREEN wires connect to the IC Igniter(if the bike has the Kawasaki supplied electronic ignition) it actually gives the coils their grounds to fire the sparkplugs. The RED wire is common to both ignition coils.
Primary(small wires) side of the coils will read between 1.8 to 3.0 ohms.
Secondary(sparkplug wire ports)side of the coil will read between 10.4K to 15.6K ohms. These ports are wired together, so it makes no difference which is used, as long as the correct coil to sparkplug configuration is followed.
The sparkplug caps should read 5K OHMS(5000), any higher, or a reading of infinity means new caps should be ordered. The heat and vibration can cause the resistor to fail, requiring cap replacement. When re-installing the old or new sparkplug caps, cut about ¼” off the sparkplug wires for a new un-corroded connection.
Never run supression sparkplug wires with sparkplug caps containing the 5000 ohm resistor, as now there will be two (2) resistances in the ignition coil’s secondary circuit, causing weak and intermittent spark.
To stress the ignition coils, take a hair dryer, heat the coils and see if the ohm readings change from cold to hot . If they do, it’s time to buy new coils.
Keep in mind, the wiring is reversed for the 550’s, 650‘s,700’s, and 750‘s, that is the RIGHT coil primary will be two wires, RED and BLACK with the secondary(sparkplugs) going to #1 and #4.
The LEFT coils primary wiring would be again two wires, RED and GREEN, with the secondary(sparkplugs) going to #2 and #3.
An indication of black and sooty sparkplugs may not mean a carb or carbs are in need of cleaning, but may mean the input voltage is low.
When checking the input voltage to the ignition coils, first have a fully charged battery, and the using a multimeter, set it up to measure VDC(Volts, Direct Current), range of 20.
Put the RED probe from the multimeter on the same terminal that either a RED wire or ones that’s RED with YELLOW stripe, and the BLACK probe on either a good frame/Earth ground or the battery Negative(-) terminal/post.
Depending on the motorcycles current draw( lighting, and other high amp needs) the reading might be 10 volts or more, but if the reading is down around 8 volts or less, this indicates a corrosion or wiring problem needs correcting to improve input voltage to the coils.
These engines have what is known as a “Wasted Spark” that is, a sparkplug will fire during an exhaust stroke. It does no damage and many other motorcycle engines have this design.
The following user(s) said Thank You: Motor Head
  • trianglelaguna
  • trianglelaguna's Avatar
08 Nov 2012 02:51
#557476
it is the only plugs under the tank that match the coils
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • trianglelaguna
08 Nov 2012 02:52
#557478
your book will show the ignition wire to coil and coil to cylinders lay out
1976 KZ900
2003 ZX12R
2007 FZ1000
08 Nov 2012 08:31
#557492
Including information about bike year and model is helpful to viewers and usually elicits better responses.
It's easy to put the information in your signature where it shows in all posted messages, past and future.
And may be changed whenever and as often as desired.
If wanting a signature showing information about the bike in posted messages, it's easy to do. Here's how:
Attachment addsig.jpg not found
Good Fortune! :)
  • Motor Head
  • Motor Head's Avatar
08 Nov 2012 10:57 - 08 Nov 2012 10:59
#557499
"File base" here on KZR, top right corner of this page in the toolbar has this link ( www.kzrider.com/filebase )
Will more than likely have a wiring diagram for you to use for this and any future electrical issues.
Last edit: 08 Nov 2012 10:59 by Motor Head.
  • nobody
08 Nov 2012 12:37
#557508
sorry about the lack of info 1982 kz1100 spectra :blush: i think i got my answer still reading thanks so much nobody
Attachment kzgrabbergreennumtwo003.jpg not found
  • MFolks
  • MFolks's Avatar
08 Nov 2012 15:03
#557517
You should do this before(if possible)installation of the wiring harness:
Cleaning Motorcycle Electrics
1. Get some of the De-Oxit electrical contact cleaner and figure on spending a good day going from the front of the bike to the back. It’s a plastic safe cleaner/preservative. www.deoxit.com is their website. It can be purchased at most Radio Shack Stores or any electronic supply places. Or use any plastic safe electrical contact cleaner(NOT WD-40 !).
2. On the older Kawasaki's, a majority of electrical connectors are inside the headlight housing requiring removal of the headlight, then the fun begins.
3. Do one set of electrical connectors at a time to avoid mixing up what connects to where. Usually disconnecting, spraying with De-Oxit and reconnecting is about all you'll need.
4. However, when encountering the green crud of corrosion, a brass wire brush may be needed on the pins you can reach. Some 400-600 grit wet and dry sandpaper strips rolled into a tube should reach the male and female pins in the more difficult to clean connectors.
5. Smoker’s pipe cleaners, cotton swabs and wooden toothpicks work as cleaning aids.
6. Really small electrical connectors may require the use of a welders tip cleaning tool assortment.
7. Most pins in the connectors are coated with a thin plating of tin, and others may be nothing more than copper or brass.
8. If moisture is added, the resulting corrosion lowers the voltage/current being carried causing dim lights, slow engine cranking, slow turn signal responce and lower input voltage to the ignition coils resulting in weak spark.
9. The left and right handlebar switch pods will need attention too as they have circuit functions like turn, horn, run/stop, and start. The older Kawasaki’s have reports of the soldered connections crumbling, if your bike has this problem, just ask, as I’ve got a repair procedure for this.
10. Usually a spritz or two with actuation of the switch is about all needed for these switches unless corrosion is detected and then careful disassembly is required.
11. The ignition switch may or may be not sealed to allow spraying the internal contacts. I urge caution if attempting to open this up as springs, and ball bearings may fly out never to be seen again!
12. If your bike has the older style glass tubed fuses, I suggest replacing them as vibration can cause internal failure. AGX is the type used, and most auto parts stores can get them for you, along with boating supply stores.
13. Clean the fuse holder clips, looking for signs of overheating(discolored insulation, signs of melting). I use metal polish on a cotton swab, followed by spraying another clean swab with the De-Oxit and then rubbing the inside of the fuse clip.
14. All battery cables must be clean and tight for maximum current transfer. Check the cables going from the Negative(-) battery terminal/post to the engine mounting bolt
15. Also the one going from the Positive(+) terminal to the starter solenoid and from there to the starter motor.
16. If any battery cable feels ”Crunchy” when flexed, replace it as possible corrosion is inside the insulation. Inspect all heavy duty battery cables and the smaller wire terminations(Bullet Connectors), for failed crimps, and those used in the electrical connectors, as they can fail over time.
17. Each "Bullet Connector" will have to be sprayed to ensure good connectivity, especially the ones going to the energizing coil of the starter solenoid.
18. The alternator output “Bullet Connectors” are usually behind the engine sprocket cover and will need inspecting and cleaning too.
20. The turn signal light sockets will benefit from a spritz from the contact cleaner along with the tail light/brake light socket.
21. Some brake light switches can be sprayed on the actuating rod, with the spray running down inside to the electrical contacts, others may be sealed requiring replacement if the switch is intermittent in operation.
22. Some people put the Di-Electric Grease on cleaned terminations/connectors, I don’t, as I’ve read/heard it can cause problems when it gets hot, actually insulating the connections, so the choice is yours to use or not.
“I spent a weekend going through every electrical connection and switch on the bike with a little scotchbrite pad and DeOxit - what a difference! Everything was brighter, gauge backlights, indicator lights, turn signals, I was getting a nicer spark, it fired up quicker, etc. Well worth my time. WELL worth it! “
From a forum member at www.kzrider.com
  • trianglelaguna
08 Nov 2012 20:32
#557547
if that is how your harness is at the moment...dont worry...it is easier as things find their match and routes and stuff gets eliminated from the needs a match list
if not and you have it mated to the bike already,disregard the following
find the tail end and start by plugging that into everything that matches from the taillight area...then work the harness towards the front end tucking and connecting whatever lines up...this will take a few re-tucks and -unplugging re-plugging but will start making more and more sense of the tangle as you go...least that is how i get em started, later .....side -cover- tank-and control/headlight stuff will require me to tuck and re-match and re-do it a few times till everything fits on the bike and has its mate... sense
nobody wrote: sorry about the lack of info 1982 kz1100 spectra :blush: i think i got my answer still reading thanks so much nobody
1976 KZ900
2003 ZX12R
2007 FZ1000
  • nobody
08 Nov 2012 22:02
#557565
thank you all. its back to gather now just needed to see a good wiring schematic .i down loaded it seen what i needed .so thanks to all..gets closer every day.
  • MFolks
  • MFolks's Avatar
08 Nov 2012 22:21
#557572
Here's a factory shop manual from Kawasaki:
www.kawiworld.com/index.php?option=com_c...icle&id=77&Itemid=99
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
18 Dec 2012 23:12
#563597
MFolks wrote: What year and model of bike do you have? Anyway, here's info on how the ignition coils and sparkplugs are wired for several models, keep in mind the K/GPz 550's,650's, 700's,and 750's are wired differently from the Z1's,Kz900's,Kz1000's and Kz/GPz 1100's:
Great information but I have a question about the red and green and red and black primary wires. Which goes to the positive terminal on the coil? The schematic in the book does not say.
Thanks,
Jim
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
