Kz750 b4 ignition coil
  • Pop147
  • Pop147's Avatar Topic Author
01 Nov 2012 22:14
#556729
Where can i get one?
  • Motor Head
  • Motor Head's Avatar
Re: Kz750 b4 ignition coil
01 Nov 2012 22:30
#556730
No eBay APP ID and/or Cert ID defined in Kunena configurationThis is one, a new Emgo. You might find one cheaper though.
  • MFolks
  • MFolks's Avatar
01 Nov 2012 23:47
#556745
The EMGO ignition coils may have molded in sparkplug wires, so keep that in mind if you order ones from Z1 enterprises. Some of the ignition coils for the bigger 4's had removable sparkplug wires, these had "Ridges" on the coil parts holding the sparkplug wires(High Tension Leads for some people).
  • Pop147
02 Nov 2012 12:41
#556802
I bought an emego but, it will not fit the standard bracket on the bike.
  • baldy110
  • baldy110's Avatar
02 Nov 2012 13:02
#556808
Is this for the 4 cylinder model if so I got one.
  • Pop147
02 Nov 2012 13:51
#556812
no its a twin
  • bountyhunter
  • bountyhunter's Avatar
02 Nov 2012 16:02 - 02 Nov 2012 16:05
#556825
Pop147 wrote: I bought an emego but, it will not fit the standard bracket on the bike.
The center to center holes on the 4 Ohm EMGO are maybe 3/4" shorter than standard so I just made a small extender piece with two holes in it out of flat metal.
You could even run it with one bolt and a long zip-tie.
Last edit: 02 Nov 2012 16:05 by bountyhunter.
  • Topper
  • Topper's Avatar
02 Nov 2012 16:13
#556826
I had the same problem with my 750 twin. I used a little piece of metal as a bracket for one of the holes. Works fine and its under the tank where no one can see it anyway.
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
