1980 kz 1000 speedo problems
- Powerstroke_fan
23 Oct 2012 21:08
like the tittle says, iam having problems with my speedo. My speedo bounces around alot usally by 10 to 15 mph bounces.. It mainly does it when speeding up and slowing down but also does it some at constant speed. You can shake the speedo with it on the bike and it will bounce. Then sometimes it dont work right at all, It will just bounce from 10 or 20 to zero. Then just out off nowhere it starts reading correctly again yet will still bounce. I would like to repair it possible just dont know what i need to fix it or where to get the parts. Any advice would be greatly appreciated. Thanks, Eric
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- roy-b-boy-b
Re: 1980 kz 1000 speedo problems
23 Oct 2012 21:55
The seal is probably out of the mechanism. The best option is Bob at Zresto. It will cost you around 100 bucks but it will be restored.
Check the cables.
Bob might be in the links or just google.
Check the cables.
- roy-b-boy-b
- 4TheKZ1000
23 Oct 2012 22:00
mine does the same thing over 60mph and up.....
- mark1122
- Keep twisting it
23 Oct 2012 22:15
i have read that there is a dampening oil in the speedo to settle the needle. when this dries up or leaks out the needle will float.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Powerstroke_fan
23 Oct 2012 22:44
so by the sounds of it, it would probably be smarter to just find another nice one.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- mark1122
- Keep twisting it
23 Oct 2012 22:52
inquire at the resto guys mension above first.
the problem i ran into with buying another, was the 1 i bought didnt work right either. thats why i desided to go with something of a more modern bike. i switched to zrx gauges.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Powerstroke_fan
28 Oct 2012 20:32
I have another question. I have a good extra tach that i dissasembled to take parts from. The question i have is. Are the tach drive and speedo drive the same? If so could i just swap faces? or could i use any parts off it to fix mine?
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- 4TheKZ1000
28 Oct 2012 20:41Powerstroke_fan wrote: I have another question. I have a good extra tach that i dissasembled to take parts from. The question i have is. Are the tach drive and speedo drive the same? If so could i just swap faces? or could i use any parts off it to fix mine?
thats a great question.....
- kz10006
- wireman
29 Oct 2012 12:46
Pull the cable out of its housing and clean/regrease to see if it helps
- Powerstroke_fan
29 Oct 2012 19:14
I have tried to grease it with no luck its the speedo that is the problem. I believe the "dampner" is bad maybe lost its oil. i will just replace it. Just thought if i could make it work.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
