No gauge light or rear running light
- strobel5
23 Oct 2012 19:51
Hello so I just got my rebuild back together and noticed that the gauge lights and rear taillight dont work. The brake light works. I tested the voltage of the red wire that runs to the fuse and there is nothing. I also test the ignition switch and the blue wire has no voltage. The red/blue and the brown wire shows continuity when I tested it at the ignition switch harness. Is there supposed to be continuity? Also the wires on the hazard switch broke from the solder, would that affect anything?
1978 kz650d(SR)
- strobel5
Re: No gauge light or rear running light
24 Oct 2012 00:35
Figured it out by myself
, there just happened to be two wires that were unplugged and loose thats why I couldnt pinpoint it.
1978 kz650d(SR)
- MFolks
24 Oct 2012 01:01
Keep this handy, in case you have further problems:
Color Codes On Most Kawasaki’s (written for 1980’s bikes)
HEADLIGHT
RED with BLACK stripe, High Beam.
RED with YELLOW stripe, Low Beam.
BLACK with YELLOW stripe, the ground circuit.
BRAKE/TAIL LIGHT Can be an # 1157 dual filament bulb
RED, Running or Tail Light.
BLUE,(sometimes with a Red stripe) Brake Light Circuit.
LEFT FRONT TURN SIGNAL Can be an #1157 dual filament bulb
GREEN, Left front turn signal circuit.
BLUE, Left front running light circuit.
RIGHT FRONT TURN SIGNAL Can be an # 1157 dual filament bulb
GREY, Right front turn signal circuit.
BLUE, Right front running light circuit.
LEFT REAR TURN SIGNAL Can be an #1156 single filament bulb
GREEN, Left rear turn signal circuit.
RIGHT REAR TURN SIGNAL Can be an #1156 single filament bulb
GREY, Right rear turn signal circuit.
I make a habit of yearly replacing the glass tubed fuses, as vibration and current surges will affect their life.
HEADLIGHT
