IC Igniter Problems
- Motor Head
Re: IC Igniter Problems
20 Dec 2012 17:52
Make sure you have the Non Resistor spark plugs, No "R" in the part #. Also what coils and wires are you using, stock or other? Is there a resistor cap, and a resistor wire? Only one resistor should be used in the secondary side of the ignition.
- badrhino
25 Dec 2012 14:06
1.5 ohm grey coils and Taylor 8mm Spiro-Pro wires.
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
Franken Z!
- MFolks
25 Dec 2012 15:46
I'm wondering if the coils should be such a low resistance. The stock coils are usually 3 ohms or less. Can you try another, higher ohmed coils for comparison?
- badrhino
26 Dec 2012 01:35
I'm sorry I meant 2.2 ohm grey dyna coils.
Franken Z!
Franken Z!
- MFolks
26 Dec 2012 01:59
Both ignition coils ohm out good on the primary and secondary connections?(Do this with all wires/sparkplug wires disconnected).
You're not using resistor plugs and NGK 5000 ohm sparkplug caps together? If so,this may be why there's a weak spark.
- MFolks
26 Dec 2012 02:41
Are the screw connections for the primary(small wires) tight? What's supplied with the ignition coils, are 10-32 X 5/16" screws, if you've used longer screws, they may be bottoming out before the ring terminals are tight, making for poor electrical connections.
- badrhino
27 Dec 2012 21:54
All of my ohm readings are within spec both primary and secondary and I am only running suppression wires with no resister caps or resistor plugs. The primary wires to the coils are tight. I got spark but not fat blue spark. :whistle:
Franken Z!
Franken Z!
- Motor Head
27 Dec 2012 22:33
In the Kawasaki manual, they have a spec for how far the spark should jump across a specified gap. This might show an otherwise working system to be at fault. About 8mm I think. But it might be farther.
Remember that it has to return back to Ground. Thats the frame/ battery -, so if the ground is in question, then energy will be low.
Whats the voltage across the coils when cranking/ kicking it over checking for the weak looking spark??
- loudhvx
08 Jan 2013 00:47
Besides the voltage issues I mentioned above, it's also possible to get a weak spark if the pickup plate was dissassembled and reassembled incorrectly. The magnets must go back in a specific orientation.
home.comcast.net/~loudgpz/GPZweb/Ignitio.../PickupAndRotor.html
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- badrhino
10 Jan 2013 19:40
I will have to look into this when I get a warm day here. Thanks!
Franken Z!
Franken Z!
