not charging
  • madmankz1000
  • madmankz1000's Avatar Topic Author
not charging
18 Jun 2006 21:18
#55421
bike is not charging. new battery lasted 210 miles at lest 20 starts. then today blinkers stoped working wile i was rideing.then started poping thruge carbs and just running like crap.got home batt dead.charged old batt for 3 hours started right up blinkers work and runs great.put tester on batt when running -11.09 volts.cleaned and even added another ground what should i try next?
  • wiredgeorge
  • wiredgeorge's Avatar
Re: not charging
19 Jun 2006 06:50
#55465
Put a "tester" on the battery when running and you got 11 VDC? What is a tester? A multimeter? Hopefully, as I will attempt to go through a few steps to get you going again and you will need one for some of this...
1. I know, I know, you have a new battery. But new batteries are sometimes defective; especially if not charged correctly initially. Buy a SMALL hydrometer at any autoparts store. It will look like a 3" long eyedropper and be filled with colored balls. It will also have a small piece of hose for connecting to the hydrometer so you can put the hose into the plug hole in each cell and draw up some fluid into the hydrometer. Note that on the packaging of the hydrometer, they give you a guide to how to interpret the number of balls that are floating. This will tell you if you have a dead cell. If you have a dead cell, you likely charged the new battery incorrectly or it was defective. If this is the case, ask how to charge a battery (if you don't know) and replace the battery. If the battery cells are OK, go to step two.
2. Measure battery voltage at idle and at 4K rpm. At idle, it should measure 12.5 VDC and at 4K rpm it should measure about 14.5 VDC. If you are getting LESS at 4K rpm, then you should look at the connections to your stator/alternator and if MORE than 14.5 VDC, look at your rectifier or regulator/rectifier. If you don't have your bike year/model and location in your signature, put it there by going into your profile and editing your signature. There are different charging systems on various KZ1000 models and really helps to know which I am talking about... if the info is already there, thanks and ignore my whining.
If you have MORE than 14.5 VDC at 4K rpm, your rectifier or regulator rectifier is BAD and should be replaced. If less, then first, remove connections to both your regulator/rectifier or the regulator AND rectifier and use contact cleaner on them and dielectic grease and reconnect securely. Retry the voltage test. If this doesn't fix your problem, you will want to look at your stator or alternator or whatever it is called for your model.
3. Last bit... On most models, the wires that come from the stator or generator or whatever it is called are all yellow and go up and terminate in a BLUE plug at the bike's junction panel. These can get to be in bad shape. You can first remove the blue plug and clean the contacts with contact cleaner and put some dielectic grease on the contacts. Check to see what the voltages are at the battery again at both idle and 4K rpm. They should be in the ranges already noted. If not, then it is likely you have issues with the stator. If this is the case, you can check voltages for your model using a Factory Service Manual... I think there should be between 20-30VAC (AC current here... change multimeter scale) on each leg but use your manual to be sure. If the rectifier or regulator/rectifier aren't getting a full does of AC, the battery won't charge. If you find the stator doesn't check out, drain your oil and remove the side cover. There are three socket head bolts holding the stator in place on most models. Remove these and tap the stator on a bench as the stator will be held in place magnetically and carefully examine the three wires that are soldered to the windings once you get the stator out. If your bike uses a different kind of generator/rotor set up, look in your Factory Service Manual for electrical checks for those components. If you have a stator type set up, I would replace it... they are on eBay all the time.
  • madmankz1000
Re: not charging
19 Jun 2006 22:09
#55645
thank you for your input.bike is 1981 kz1000 ltd j head.i will try all of what you sugjested.yes i ment multimeter by tester.iwill get back after i have tryed all that thank you.
  • sbol1508
  • sbol1508's Avatar
Re: not charging
05 Oct 2006 05:59
#81963
i recently purchased the same bike earlier this year.. (81 kz1000 ltd).. and it just so happens i am having the same problem... what ended up being the problem, and how did u fix it?
  • ran429
  • ran429's Avatar
  • Master of FREE rides!
Re: not charging
06 Oct 2006 09:49
#82239
i have a kz900 1976 model, the 3 yellow wires leading off the Rectifier came loose on mine causing this same problem, Pull the rectifier off and push the clips back out of the connector and solder them lightly.
Or purchase a new rectifier from www.z1enterprizes.com I can guarantee it will charge. Also check the ground connection on the right side of the engine block, mine also came loose which abstructed the charging.
  • madmankz1000
Re: not charging
07 Nov 2006 21:39
#90407
this may sound strange.but i tryed lots of things. and just when i was about to replace the stator.(had been rideing useing a battery tender. plug in every 300 miles or so)when the head lamp whent bad when i replaced the bulb i also cleaned all the conecters in there and havet had a ploblem yet.
  • donthekawguy
  • donthekawguy's Avatar
Re: not charging
08 Nov 2006 08:30
#90467
My charging problems drove me nuts for over a year. 3 stators, two batteries and a reg/rec combo unit later, I found the accel coils I picked up on ebay were bad. :angry:
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
Re: not charging
08 Nov 2006 10:06
#90485
DON
How did the coils cause this and how did you trace it to the coils?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • donthekawguy
Re: not charging
08 Nov 2006 17:15
#90602
I had changed everything on it and checked and re-checked all the wires and grounds. After my third stator and all the new parts, I said to myself, "self, the only used parts on this bike are the coils". I got a set of green dynas from Jeff and all was good.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
  • wireman
  • wireman's Avatar
Re: not charging
08 Nov 2006 20:42
#90653
you just wanted the green coils because they match your bike!:P
  • kzwolfsr
  • kzwolfsr's Avatar
Re: not charging
03 Dec 2006 16:27
#97138
I had the same prob with my bike right after I bought it. I bought a new battery for it cause the first owner didnt check the battery fluid levels and I wasnt in any position to find out if I could bring it back. The dumb^ss kept telling me it needed a new battery when all he had to do was add fluid well I changed that then I found the battery would die right after a day of the bike just sitting and it only charged up to 12v at 4000 rpm. So I suspected the regulator retifier was bad seeing that it over worked itself with a dead battery before. what I think I did to fix it I dont really know. I unplugged it while the bike was running and the rpm changed like it went up then came back down when I plugged it back in(unplugged 2 yellow wired connection from stator). Whatelse? I might of cheaned up a dirty connection when I took it out to wash it and last I used my ohmmeter and diode tester on my meter to test it, Probably gave it a bit of shock treatment
Original man of the Caribbean
