DEVELOPED A GREMLIN........
  • MentalMike
  • MentalMike's Avatar Topic Author
  • God Bless America!
13 Oct 2012 18:22 - 13 Oct 2012 18:23
#553677
Been a while but.....my 78 650 Custom......she has begun to sputter and cut out on me while riding, but will usually start up again...eventually. I had just replaced the stator and rode her to work for a few days before the problem started. Also, no headlight or turn signals now. I'm getting 12v at the battery and spark at all four spark plugs. Wiring harness and connections look ok from what I can see. When she runs, she runs fine and then.......
Any thought's on where to start?
I swear to God, it's like I live in a trailer of common sense, and stare out the window at a tornado of stupidity.
1976 Kawasaki KZ900
1978 Kawasaki KZ1000A
1978 Kawasaki KZ650 C
1984 Kawasaki ZN1100 LTD
1985 Kawasaki ZX900A2 GPZ (2)
1985 Kawasaki ZL900 Eliminator
2013 Kawasaki C14 Concours
Last edit: 13 Oct 2012 18:23 by MentalMike.
  • rcook52459
  • rcook52459's Avatar
Re: DEVELOPED A GREMLIN........
13 Oct 2012 22:32
#553697
what's battery voltage when bike isidling?i think it should be around 12.8 volts.have volt meter on battery and start it.seewhat battery does.if volts drop more than 2 volts have battery check.
1983 750 spectre,all stock almost 16,000 on it on 1980 Suzuki gs1000l
13 Oct 2012 23:22
#553702
If you're only getting 12v at the battery something is wrong. Take a look at the FSM on how to test the rectifier / regulator. My '77 has a different charging system, but it was experiencing similar symptoms. It turned out to be a problem with the rectifier that was easily diagnosed using the FSM. I installed a replacement from Oregon Motorcycle Parts (see link) and now the charging system is performing perfectly. Ed
www.oregonmotorcycleparts.com/Products.html
  • OldSchoolZ
  • OldSchoolZ's Avatar
14 Oct 2012 01:59 - 14 Oct 2012 01:59
#553725
Check all electrical connections as well, sometimes its something simple.
Remember, don't work on your bike so much you never ride it.
Last edit: 14 Oct 2012 01:59 by OldSchoolZ.
