81 kz1000 ltd wiring
  • rocketman
  • rocketman's Avatar Topic Author
13 Oct 2012 16:11
#553658
I have 2 blk/yel wires one on each right side battery box bolts. I realize they are grounds but to what? One is cut and the other has empty bullet connector.
1977 Kawasaki Kz650B1
1977 Yamaha XS7502D
1981 kz1000 k1
Re: 81 kz1000 ltd wiring
13 Oct 2012 16:36
#553661
The wiring diagram in KZr's FILEBASE shows one blk/yel wire with a dual connector designated as "Electric Accessory Leads," which wire appears to reach ground near the battery.
Perhaps the other cut/unused blk/yellow wire was the ground for a component no longer in service, such as a fuel level sender.
Good Fortune! :)
  • rocketman
17 Oct 2012 15:37
#554346
I have not found anything thats missing there! I had the red plug melted that goes to the rect/reg so I checked everything(stator and reg/rect and it all checks out with multimeter. I got ahold of another rectifier with a good plug, and the other side of that same red plug coming from stator. When splicing it in to stator wires does the order in which the yellow wires go in the plug matter? I never marked there position on the plug when I cut the old one off.
1977 Yamaha XS7502D
1981 kz1000 k1
  • Motor Head
  • Motor Head's Avatar
17 Oct 2012 22:23
#554413
Order of the Yellows is not important.
Grab the service manual for your bike, in my signature. ;)
  • rocketman
25 Oct 2012 15:25
#555722
Rewired stator,changed rectifier,replaced one coil,new plugs and IT RUNS!!!
1977 Yamaha XS7502D
1981 kz1000 k1
