Dyna S ignition
  • baldy110
  • baldy110's Avatar Topic Author
Dyna S ignition
05 Oct 2012 13:26
#552614
Not a problem question just a why question. Does anyone know why the Dyna S instructions have you time the system at full advance instead of using the "F" mark at idle.
Re: Dyna S ignition
05 Oct 2012 14:55 - 05 Oct 2012 14:56
#552633
baldy110 wrote: Not a problem question just a why question. Does anyone know why the Dyna S instructions have you time the system at full advance instead of using the "F" mark at idle.
Have wondered the same thing.
Meanwhile, I ignore the Dyna-S timing instruction, and use the F mark as if fitted with points, and enjoy satisfactory results. And happily rely on the advancer to function as intended by Kawasaki. Moreover, it's easy to watch and see whether the advanced marks align at higher rpm when viewed with a timing light.
Am thinking maybe the Dyna folks are more concerned about the owner achieving spot-on advance timing as opposed to spot-on idle speed timing.
As known, each Dyna-S module may be separately adjusted through a small range. However, guessing most owners simply align F mark on 1/4 and call it done.
Good Fortune! :)
Last edit: 05 Oct 2012 14:56 by Patton.
  • baldy110
Re: Dyna S ignition
05 Oct 2012 20:15
#552663
Yeah that is what I do but just wondered if there was a particluar reason Dynatek does it this way.
  • Motor Head
  • Motor Head's Avatar
Re: Dyna S ignition
05 Oct 2012 20:50
#552672
The total advance on an ignition system should be checked, to make sure that the Total is not to much, as it can be very damaging to an engine. At higher RPM's you won't here any Detonation like when a motor makes these sounds at lower RPM. To much Initial, or to much total either is bad.
