How to Remove Speedo Needle
  • yakimasy
  • yakimasy's Avatar Topic Author
17 Jun 2006 16:06
#55178
I was taking apart an extra speedo that I have.
I realized the needle has a cover that comes off easy enough, but how do you get the needle off so you can remove the face plate? I thought I would ask before I break something.
Thanks
  • fixer5000
  • fixer5000's Avatar
Re: How to Remove Speedo Needle
18 Jun 2006 04:26
#55246
the needles can be pried off very carefully. i used two screw drivers. just be sure you pry against the faceplate screws and not the faceplate itself...steve
1978 kz650b pretty much stock
massachusetts
  • kawtoy
  • kawtoy's Avatar
18 Jun 2006 08:11
#55263
I use 2 spoons. Use them like you were eating with them. Put the bottom on the screws so you don't mess up the face plate. Use them like a pry bar and be sure to pry evenly. It will come off pretty easily.
Harley Davidson- Turning gas into noise without the harmful affects of horsepower for over 100 years.
