Replacing Handlebar Controls
  • Shuagrr
  • Shuagrr's Avatar Topic Author
27 Sep 2012 16:06 - 27 Sep 2012 18:03
#551203
Hello,
I was wondering if someone could point me in the direction of replacement handlebar controls? I have a '83 KZ650 CSR, and recently replaced the handlebars. The new bars are shorter than the previous bars(apes), and the original controls and levers are cramped. So in essence I am looking for:
new (shorter) clutch lever and signal/horn/HB controls for the left side.
new brake lever, throttle/housing, and brake fluid container for the right side.
I also want to relocate the starter/kill switch. So not only will I need the part, but would also appreciate some suggestions for placement.
The plastic housing between the Speedo & Tach (HB/Neutral/Signals) is cracked and missing plastic, would item #03-0744 from Parts-N-More work as a replacement? Would the indicator lights work?
Cheers,
Shua
Good work ain't cheap. Cheap work ain't good.
-Norman Collins
1983 KZ650 CSR
Last edit: 27 Sep 2012 18:03 by Shuagrr.
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
Re: Replacing Handlebar Controls
27 Sep 2012 20:47
#551247
Shuagrr wrote: Hello,
Cheers,
Shua
what do u mean by shorter. do u mean lower or the grip area is shorter?
amost any electic controls could be converted. but u would want a wiring diagram to sort out the new wires. some of the modern bikes have thinner controls that would help in the grip area, but u may need a custom throttle cable from motion pro.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
The following user(s) said Thank You: Shuagrr
  • Shuagrr
28 Sep 2012 15:45 - 28 Sep 2012 15:47
#551406
The grip area shorter. I have attached a image, it is somewhat hard to see but the lever sticks out. I am not sure if once I replace the left controls it will make a difference, but I am getting bar-end mirrors so I will be replacing the current mounting anyways.
-Norman Collins
1983 KZ650 CSR
Last edit: 28 Sep 2012 15:47 by Shuagrr. Reason: attachment didn't work
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
28 Sep 2012 16:16
#551411
i'm just thinking out loud here.
most bikes should have the same amount of room for the controls. would it be cheaper and easier to look into a dif set of bars?
what type of bars r u using? can we see a pic of the bars on the bike?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
