Bare Bone Stand Alone Module For You
- peavylotus
- Movin on up
26 Sep 2012 03:20
I made a Stand Alone wiring set up from a old computer power supply. I kept the simplicity though leaving room for growth.
I did have a computer cooling fan on this but it fried when the bike started so I need a resistor so it doesn't go up in smoke like the first one. This needs a cooling fan because the REG REC gets warm.
Materials
Computer Power supply box
Sealed Led Acid Battery 12v 5Ah
Regulator/Rectifier
LED Rocker Switch
Terminal Post
Fused Wire
Heat Shrink
A little soldering skill to be sure it holds up
I figured I would post this here in case anyone needs ideas with wiring a bare bones system
You can also check out my project 'Self Sustaining Cafe Project'
Confirmed spark prototype harness
[attachment:1]C:\fakepath\DSCN0812.JPG[/attachment]
What isn't mentioned in the picture is the ignition wires. They are soldered to the positive terminal post.
[attachment:2]C:\fakepath\explination.png[/attachment]
[attachment:3]C:\fakepath\DSCN1346.JPG[/attachment]
[attachment:4]C:\fakepath\DSCN1352.JPG[/attachment]
[attachment:5]C:\fakepath\DSCN1353.JPG[/attachment]
[attachment:6]C:\fakepath\DSCN1366.JPG[/attachment]
These are the ignition hook ups, the two prong goes to the coils and the single goes to the DYNA
[attachment:7]C:\fakepath\DSCN1360.JPG[/attachment]
These are the fused connectors for the Lights and blinkers. I wired them like this to free up my terminal post.
[attachment:8]C:\fakepath\DSCN1358.JPG[/attachment]
Materials
Regulator/Rectifier
LED Rocker Switch
Terminal Post
Fused Wire
Heat Shrink
1980 KZ 1045 LTD Currently Workin' It Out
