making the LED turn signals flash??
- vernons
22 Sep 2012 22:14
guy's
only thing not working on my new bike is the after market blinkers.... they are led's... been internet researching... from what i read i need a 2-pin led flasher with ground wire??? should this solve the problem??? thanks for providing some more input
- 4TheKZ1000
Re: making the LED turn signals flash??
22 Sep 2012 22:33 - 22 Sep 2012 22:40
Last edit: 22 Sep 2012 22:40 by 4TheKZ1000.
- OldSchoolZ
23 Sep 2012 02:06yep, they need a resistor, the LED's dont draw enough amps to make the flasher relay work.4TheKZ1000 wrote: LED flashing unit from these guys.....proplem solved.....
www.cwswiring.com/Shop.html
Remember, don't work on your bike so much you never ride it.
- BikeDude2002
- Today is a good day to ride...
23 Sep 2012 23:33
Adding resistors are a waste of power (& time). Use the units from
78 KZ650 SR
90 Yamaha Radian
90 Yamaha Radian
- OldSchoolZ
24 Sep 2012 01:10Im sure its not a magical box :lol: Take it apart, bet theres a small resistor in there.BikeDude2002 wrote: Adding resistors are a waste of power (& time). Use the units from www.cwswiring.com/Shop.html
- bountyhunter
24 Sep 2012 01:35Nope, it's s solid state flasher that doesn't rely on current to flash like a bimetallic thermal unit does.OldSchoolZ wrote:Im sure its not a magical box :lol: Take it apart, bet theres a small resistor in there.BikeDude2002 wrote: Adding resistors are a waste of power (& time). Use the units from www.cwswiring.com/Shop.html
I agree the resistors are just a waste of money and power, you can get solid state flashers everywhere these days, even Kragens and Auto Zone.
- bountyhunter
24 Sep 2012 01:39Nope, it's s solid state flasher that doesn't rely on current to flash like a bimetallic thermal unit does.OldSchoolZ wrote:Im sure its not a magical box :lol: Take it apart, bet theres a small resistor in there.BikeDude2002 wrote: Adding resistors are a waste of power (& time). Use the units from www.cwswiring.com/Shop.html
If anybody wants to build one, here is the circuit I am using on mine. It will work with either LED or standard bulbs.
- OldSchoolZ
24 Sep 2012 01:48
Damn Im getting old :laugh:
- BlackZ1R
- Kawasaki in my blood
24 Sep 2012 19:35OldSchoolZ wrote: Damn Im getting old :laugh:
some of the electronic gurus on here are good...
Kawasaki
Someone once told me to marry that motorcycle I was riding ......there's times I wish I hadda listened .
- tjgonz
24 Sep 2012 19:42
Im in the process of wiring mine also. Have LED signals & relay but all signal wire was removed from my harness already.
Any of you guys have a good diagram or instructional I could use to wire them from scratch?
Thanks & sorry for the thread jack.
- bountyhunter
25 Sep 2012 01:02 - 25 Sep 2012 01:02I have the diagram for my 750 twin.tjgonz wrote: Im in the process of wiring mine also. Have LED signals & relay but all signal wire was removed from my harness already.
Last edit: 25 Sep 2012 01:02 by bountyhunter.
- tjgonz
