making the LED turn signals flash??
  • vernons
  • vernons's Avatar Topic Author
22 Sep 2012 22:14
#550323
guy's
only thing not working on my new bike is the after market blinkers.... they are led's... been internet researching... from what i read i need a 2-pin led flasher with ground wire??? should this solve the problem??? thanks for providing some more input
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
Re: making the LED turn signals flash??
22 Sep 2012 22:33 - 22 Sep 2012 22:40
#550327
LED flashing unit from these guys.....proplem solved.....
www.cwswiring.com/Shop.html
Last edit: 22 Sep 2012 22:40 by 4TheKZ1000.
  • OldSchoolZ
  • OldSchoolZ's Avatar
23 Sep 2012 02:06
#550351
4TheKZ1000 wrote: LED flashing unit from these guys.....proplem solved.....
yep, they need a resistor, the LED's dont draw enough amps to make the flasher relay work.
Remember, don't work on your bike so much you never ride it.
  • BikeDude2002
  • BikeDude2002's Avatar
  • Today is a good day to ride...
23 Sep 2012 23:33
#550528
Adding resistors are a waste of power (& time). Use the units from www.cwswiring.com/Shop.html
78 KZ650 SR
90 Yamaha Radian
  • OldSchoolZ
24 Sep 2012 01:10
#550544
BikeDude2002 wrote: Adding resistors are a waste of power (& time). Use the units from www.cwswiring.com/Shop.html
Im sure its not a magical box :lol: Take it apart, bet theres a small resistor in there. ;)
  • bountyhunter
  • bountyhunter's Avatar
24 Sep 2012 01:35
#550557
Nope, it's s solid state flasher that doesn't rely on current to flash like a bimetallic thermal unit does.
I agree the resistors are just a waste of money and power, you can get solid state flashers everywhere these days, even Kragens and Auto Zone.
  • bountyhunter
24 Sep 2012 01:39
#550558
If anybody wants to build one, here is the circuit I am using on mine. It will work with either LED or standard bulbs.
  • OldSchoolZ
24 Sep 2012 01:48
#550559
Damn Im getting old :laugh:
  • BlackZ1R
  • BlackZ1R's Avatar
  • Kawasaki in my blood
24 Sep 2012 19:35
#550661
OldSchoolZ wrote: Damn Im getting old :laugh:
:P you're not alone. :laugh:
some of the electronic gurus on here are good... :cheer:
Kawasaki
Someone once told me to marry that motorcycle I was riding ......there's times I wish I hadda listened .
  • tjgonz
  • tjgonz's Avatar
24 Sep 2012 19:42
#550664
Im in the process of wiring mine also. Have LED signals & relay but all signal wire was removed from my harness already.
Any of you guys have a good diagram or instructional I could use to wire them from scratch?
Thanks & sorry for the thread jack.
  • bountyhunter
25 Sep 2012 01:02 - 25 Sep 2012 01:02
#550736
tjgonz wrote: Im in the process of wiring mine also. Have LED signals & relay but all signal wire was removed from my harness already.
I have the diagram for my 750 twin.
Last edit: 25 Sep 2012 01:02 by bountyhunter.
  • tjgonz
  • tjgonz's Avatar
26 Sep 2012 05:20
#550938
Youre the man, Thanks a ton!
