msd shift light
  • lushbaugh
  • lushbaugh's Avatar Topic Author
  • everybodys a pro......
msd shift light
20 Sep 2012 19:15
#549940
im using a 8952 light that uses the pills, with a 3 k pill it lights up at six and i cut two wire loops for 4cyl calibration. any ideas?
79 kz1000 ltd all apart
the best advice i can give is dont take dnthavakawmans advice..
  • loudhvx
  • loudhvx's Avatar
Re: msd shift light
21 Sep 2012 19:19
#550170
Is it a shift light for cars (with distributors)?
If so, then it will light up at double the RPMs if you only use one coil wire.
You need a circuit to combine the two coil signals, or set the shift light for 2-cylinder motor (if that's an option).
Incidently, why do you want a shift light at 3k rpm?
  • taildragger1197
  • taildragger1197's Avatar
Re: msd shift light
21 Sep 2012 20:13 - 22 Sep 2012 09:17
#550179
I am using the MSD 9852 on my bike and if my memory is correct, the shift light sees the "lost spark" ignition system on a Kawasaki inline-four as a two cylinder. So you have to cut 3 wires. It has been a while since I installed it but here are the instructions if it helps.
Also, if you are using an air shifter or something that interrupts the ground to the coils, DO NOT connect the light to +12volt at the coil like the instructions show. If you do, every time you shift, the light will "self test" again and give you a false flash. Just connect it where the +12volt supply won't be interrupted.
Union City, Tennessee
1979 KZ1000 LTD B3
1979 KZ1000(1260)LTD S/G Pro ET
1993 ZX11 D1 Ninja
Last edit: 22 Sep 2012 09:17 by taildragger1197.
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
Re: msd shift light
21 Sep 2012 20:17 - 21 Sep 2012 20:36
#550181
No eBay APP ID and/or Cert ID defined in Kunena configurationTry this.....this will give you a signal from each coil....it is for a dual coil setup you have....I set my tach at 4-cyc but its a auto meter not msd.
Attachment msd-8911_w.jpg not found
Last edit: 21 Sep 2012 20:36 by 4TheKZ1000.
  • lushbaugh
Re: msd shift light
22 Sep 2012 16:43
#550283
i can set it to two cyl mode thanks guys
  • 4TheKZ1000
Re: msd shift light
22 Sep 2012 18:58
#550295
lushbaugh wrote: i can set it to two cyl mode thanks guys
I really doubt thats going to work!!
  • 4TheKZ1000
Re: msd shift light
22 Sep 2012 18:58 - 22 Sep 2012 19:09
#550296
Setting the tach to 2cyc wont work....you still have to provide the tach with a correct 2 coil signal, untill you do that you will have problems.
Last edit: 22 Sep 2012 19:09 by 4TheKZ1000.
  • taildragger1197
Re: msd shift light
22 Sep 2012 19:29
#550299
I am pretty sure it will work. I have been running mine as a two cylinder with the signal from just one coil since 1994. Eighteen years without a problem. ;)
1979 KZ1000 LTD B3
1993 ZX11 D1 Ninja
The following user(s) said Thank You: lushbaugh
  • lushbaugh
Re: msd shift light
22 Sep 2012 20:21
#550308
yep that was it
  • taildragger1197
Re: msd shift light
22 Sep 2012 20:43 - 22 Sep 2012 20:46
#550311
lushbaugh wrote: yep that was it
Let me give you another little tip. Toss the 12 volt incandescent bulb and get a LED bulb. The bulb that comes with the light is cheap and fragile and you will react quicker to the LED bulb. Also set your pill @ 200rpm below where you want to shift at. That gives you a chance to react and not go over your set rpm.
Don't tell anyone about these tips O.K.? I wouldn't want everyone to find out about these things. :huh:
1979 KZ1000 LTD B3
1993 ZX11 D1 Ninja
Last edit: 22 Sep 2012 20:46 by taildragger1197.
  • lushbaugh
Re: msd shift light
22 Sep 2012 21:37
#550318
lol mine is led already and alread set my pill 600 lower cause i let it shine for a sec while i glance the tach
