No high beam
  • built408
  • built408's Avatar Topic Author
No high beam
20 Sep 2012 18:16
#549933
Is their a separate bulb for the high beam? My high beam will not turn on I'm not sure if its the switch or time for a new bulb.The regular running light still works but if I switch on the high beam the light goes dark. Thanks.
1978 KZ1000 A2A with MKII body you know you like it
  • shanekfalcon
  • shanekfalcon's Avatar
Re: No high beam
20 Sep 2012 18:25
#549934
In Australia, its the one bulb for both so I would pull the bulb out and have a look inside. Failing that, perhaps the switch.
  • bountyhunter
  • bountyhunter's Avatar
Re: No high beam
20 Sep 2012 20:37 - 20 Sep 2012 20:40
#549954
Two separate filaments inside of the bulb. I know that one can fail without the other failing.
If it's a 7" round, this is a good replacement:
www.summitracing.com/parts/WAG-H6024/
any brand H6024 lamp will probably drop in no problem.
Last edit: 20 Sep 2012 20:40 by bountyhunter.
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
Re: No high beam
20 Sep 2012 23:08 - 20 Sep 2012 23:11
#549989
As slow as your bike is you could use a candle...worried about a high beam....come on man !.... :woohoo: :woohoo: :woohoo:
Last edit: 20 Sep 2012 23:11 by 4TheKZ1000.
  • martin_csr
  • martin_csr's Avatar
Re: No high beam
21 Sep 2012 09:57 - 23 Jan 2013 00:19
#550045
Last edit: 23 Jan 2013 00:19 by martin_csr.
  • bountyhunter
Re: No high beam
21 Sep 2012 16:01 - 21 Sep 2012 16:01
#550125
The H6024 sealed beam I listed above is a halogen sealed unit that drops in with no modification (the "H" designator means halogen type). Increases light about 3X. Same wattage as stock light. Can't beat it for $12.
Last edit: 21 Sep 2012 16:01 by bountyhunter.
  • martin_csr
Re: No high beam
21 Sep 2012 18:03 - 23 Jan 2013 00:19
#550149
