DYNA S power wire getting hot HELP!!
  • peavylotus
  • peavylotus's Avatar Topic Author
  • Movin on up
20 Sep 2012 02:01
#549812
I get hot blue spark when I hook the power wire for the DYNA and Coils to the positive battery terminal. Sparking when turned over. Loudhvx's barebones diagram for KZ1000 Dyna S says the white/red wire coming out of the regulator/rectifier goes to the battery and the brown wire meets up with a wire coming off the positive terminal with separation of a ignition switch. I am using the stock size wiring but is it simply to small of wire and too much draw or am I completely wrong? or is the wire supposed to heat up a bit. It doesn't get too hot to touch. NEED HELP TO HEAR THE BEAST RUN!
Attachment 77kz1000bareBonesForSnerff-aae64d06473c85b83a9a7e0d24667f59.GIF not found
1980 KZ 1045 LTD Currently Workin' It Out
  • peavylotus
  • Movin on up
Re: DYNA S power wire getting hot HELP!!
20 Sep 2012 03:36
#549815
NEVERMIND!!!!!!!!!!!!!! I fixed it and it runs!!!!!!!!!!!!!!!!!!!!! AHHHHHHHHHHHHHHHHH
I did nothing to fix it just let the wire warm up to see how bad it got. The problem is the wire is too small of a guage and is drawing juice for both coils and the DYNA S. IF you have this problem just get a bigger wire!
  • kzz1king
  • kzz1king's Avatar
20 Sep 2012 10:09
#549845
peavylotus wrote: NEVERMIND!!!!!!!!!!!!!! I fixed it and it runs!!!!!!!!!!!!!!!!!!!!! AHHHHHHHHHHHHHHHHH
Yep, or do the coil/relay mod. So how does it run?
Wayne
Home built KZ1000 turbo setup
  • peavylotus
  • Movin on up
21 Sep 2012 03:56 - 21 Sep 2012 03:58
#550022
It runs ugly to be frank...I havent adjusted the carbs yet and the color of the exhaust wrap only changed on three cylinders. So my number 3 cylinder isnt fireing. But ill work out the kinks. When I finish my power box I'm made for the bike. (A battery and regulator/rectifier in a old computer power supply box with a cooling fan and a on off switch)
Last edit: 21 Sep 2012 03:58 by peavylotus. Reason: typo
