fuze with wires
- 81KZ750E
fuze with wires
19 Sep 2012 22:17
[attachment:1]C:\fakepath\wires.jpg[/attachment]
hey i have a 1981 kz 750 E2 with the four cylinder i have this fuze box with two fuzes in it and a red wire coming out one end and 2 wires coming out the other end where does this go on my bike and what is it for i have a feeling it's for the guages but not sure because they don't work currently but are suppose to be in working order once the wires are hooked up i'm not good with wiring as you can see it's my first bike now i had it running good when i got it other than it won't run off choke and i took apart carbs and cleaned them good 3 times and found out that there is two holes in two of the diaphrams so now i wonder if i can fix the diaphrams i have or where to find new ones.
- Motor Head
Re: fuze with wires
19 Sep 2012 22:29 - 19 Sep 2012 22:43
Your picture did not post, try resizing it.
It sounds like you have discovered the Accessory fuse box. It is there for wiring in other circuits, like heated grips, or a power socket etc.
There are some sellers on Feebay who have diaphragms for sale, to replace just the rubber section no slide. These vary in price throughout the year, but probably around $25 ea.
Here is a link to a Feebay store where a breaker has several to chose from, complete slides.
stores.ebay.com/Smokin-Cracks-SportBikes..._fsub=3&_sid=5595364
Last edit: 19 Sep 2012 22:43 by Motor Head.
- DiamondSkyBlue1000
Re: fuze with wires
19 Sep 2012 22:31 - 20 Sep 2012 10:26
The photo didn't come through.
You have to use the Attachments feature below the message box, click the Add File box to get started.
Okay, I'm at work now and am using a larger monitor...
I can see a couple of fuses marked as accessory coming off of the battery, one goes to a blue/white wire which goes to a plug up near your headlight. It pairs with a yellow/black wire to make a power tap for your use. The other fuse goes to a black (black/white? hard to tell) wire that pairs up with a yellow/black wire to make another power tap. That is a nice feature!
Last edit: 20 Sep 2012 10:26 by DiamondSkyBlue1000.
Re: fuze with wires
19 Sep 2012 23:23Attachment picpostnewsite912x671.jpg not found
Last edit: 23 Jan 2013 00:24 by martin_csr.
