mosfet, stator and rotor swap?
- pburnhamb
19 Sep 2012 00:34
Hey , looking for a better rrctifier/ regulat or and stumbled across the mosfet type. he problem .is my 78 kz 650 has 2 ac leads, not 3 . I dont know too much about this but i assume i cant run a modern mosfet reg/rect that has 3 ac leads from my 2 ac stator.. correct? If so will a stator and rotor from a 650/750 with 3 ac leads be swapped? If so will i then be able to use the mosfet type? Would anything else have to be swapped? Thank you
1978 kz650b (810, 750 head)
1976 kz900
1977 xs650
1976 kz900
1977 xs650
- Motor Head
Re: mosfet, stator and rotor swap?
19 Sep 2012 10:22 - 19 Sep 2012 10:22
No eBay APP ID and/or Cert ID defined in Kunena configurationI haven't installed one, but the listing is for the updated unit with a newer heat sink board. Used with either the 2 wire single phase, or the 3 wire 3 phase alternators.
So it should be a direct replacement, following their instructions.
Of course they would be available elsewhere and possibly cheaper. Good Luck.
Last edit: 19 Sep 2012 10:22 by Motor Head.
- pburnhamb
19 Sep 2012 13:56
What listing? Who is "they/their"??? Also will a 3 phase stator & ritor swap onto my 78 650 from a 650 with 3 phase
1976 kz900
1977 xs650
1976 kz900
1977 xs650
- Motor Head
19 Sep 2012 21:38 - 19 Sep 2012 21:41
No eBay APP ID and/or Cert ID defined in Kunena configurationAre you viewing from a mobile phone or something? There is a widget which shows a listing on Ebay for what you referred to, a Mosfet R/R. It shows up right in the KZR thread, so I can't think of why you can't see it except for the phone angle. Try this link:
Anyway, not sure about the Rotor/ Stator swap. Do a search, I think this has been asked in the past, but can't remember.
Last edit: 19 Sep 2012 21:41 by Motor Head.
