Swap out 84 kz750 gauge cluster for 81 750 cluster
- Rchenko
18 Sep 2012 19:33
I find the 84 kz750 cluster to look a bit trashy and in this case they look and act trashy, so I was wondering if anyone out there had any luck installing a more classic looking cluster from an 81 model? Will it fit?
Cheers!
Cheers!
Re: Swap out 84 kz750 gauge cluster for 81 750 cluster
19 Sep 2012 12:49 - 23 Jan 2013 00:25
one problem you'll encounter is that your bike has an electronic tachometer, whereas most earlier 750s are cable driven. The Spectres & F1 Ltd-Shaft look to be electronic. Their meter brackets look similar to yours. I would try to get a center-to-center measurement on the bracket's mounting points.
Last edit: 23 Jan 2013 00:25 by martin_csr.
- Rchenko
22 Sep 2012 11:59
Thanks Martin. I will do that. I think I have a line on a specter parts bike.
Cheers!
Cheers!
