shift light
- lushbaugh
- everybodys a pro......
shift light
14 Sep 2012 22:30
where should i set mine with the 1105 stock head?
79 kz1000 ltd all apart
the best advice i can give is dont take dnthavakawmans advice..
- wireman
Re: shift light
14 Sep 2012 23:05
What cams,welded crank,where does it stop pulling?
- Kraz1
Re: shift light
14 Sep 2012 23:18
9500 to 9800 rpm's is your shift point with the stock head, and cams. It's only spinning after that, not pulling.
- wireman
Re: shift light
14 Sep 2012 23:34
with stock head and cams id say its out of steam closer to 8-8500 in reality,but shifting a little over that will keep it in the sweet spot when shifting if you really feel the need to wail on it! :woohoo:
- lushbaugh
Re: shift light
15 Sep 2012 13:49
yea my shift light takes pills so im asking to see what i need to order, i generally shift at 8 or set my light there to say hey dummy eye on the needle...
