Bypassing Computer on a 1980 KZ1000G Classic
  • Z Parts
  • Z Parts's Avatar Topic Author
13 Sep 2012 22:34
#548548
Is there a way to by pass the computer on my 1980 KZ1000 Classic to get it to run.
  • MFolks
  • MFolks's Avatar
Re: Bypassing Computer on a 1980 KZ1000G Classic
13 Sep 2012 23:05
#548557
I doubt it,as it controls the fuel pump & injectors. Some of the "G" models have been changed to run with carbs.
The airbox has a switch that can develope burned contacts, preventing the engine from running.
Read this:
KZ1000 G Model First Generation FI
So for anyone else with this one-year-only Kz1000 "Z1 Classic", here are a few ways to find this switch:
1) 1979 Datsun 280zx "Throttle Valve Switch"
2) 1980 Datsun 200sx, find it at
Remartautoparts.com, with Remart part # TH114
3) "BECK ARNLEY 158-0492 Fuel Injector Throttle Switch" (NOTE: the 158-0492 is a 'master' part number apparently that most Auto parts stores can use to find all the vendors of this switch)
4) 1986 Nissan 300ZX Turbo "Throttle Position Sensor",
the part is mfg. by 'Nile'
1980 KZ 1000 G1 (Z1 Classic)
I took this from the www.kzrider website.
below is a description with autos and part numbers for this throttle switch. ONLY COST $80.
This little switch has *profound* affects on the usability of the bike. Only 1 side of the 2-pole switch was intermittently bad, and it basically made the bike UNUSABLE.
I found the switch today at O'Reilly Auto Parts store here in Silicon Valley -- they used the matching autos to look it up in the O'Reilly computer in the store (using 'Kawasaki' or the Kaw part number was *not* useful, it had to be a car with the year/model or a part number for the switch).
The local O'Reilly store today looked it up for the 1979 Datsun 280zx and they HAD ONE IN STOCK. Put it on the bike, I'm gone on a 45-minute ride around the Valley!
NARY A HICKUP. Bike is fiiiiiine.
If I were you, I'd buy one to have on hand if your bike acts up like this rider's did.
The following user(s) said Thank You: Z Parts, wireman
