Removing Coils
- badrhino
Removing Coils
12 Sep 2012 23:38
Does soomeone want to explain to me how to get the coils out. I have the original coils on a 1980 KZ100 ltd. I can't even get to the screw on the back of the coils. The front ones I can reach but still having problems getting them loose. Could they not use a bolt and make it so you could reach them?
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
Franken Z!
- wireman
Re: Removing Coils
12 Sep 2012 23:47
Usaully they use a long phillips head screw with nut on bottem of each side of coil,then they have another nut under that where coil mounts through frame bracket.
You should just need to remove the 2 bottem nuts on each coil
- badrhino
Re: Removing Coils
12 Sep 2012 23:50
Ok thanks Wireman, I just noticed that there were nuts on the bottom. :ohmy: lol
Franken Z!
Franken Z!
- wireman
Re: Removing Coils
12 Sep 2012 23:58
Ive done much,much worse things! :woohoo:
- badrhino
Re: Removing Coils
13 Sep 2012 00:28
I just assumed the nuts on the bottom were welded to the frame bracket.
Franken Z!
Franken Z!
- OldSchoolZ
Re: Removing Coils
13 Sep 2012 00:41For asking that, you should gift me your avatar! :lol: :silly:badrhino wrote: Does soomeone want to explain to me how to get the coils out. I have the original coils on a 1980 KZ100 ltd. I can't even get to the screw on the back of the coils. The front ones I can reach but still having problems getting them loose. Could they not use a bolt and make it so you could reach them?
Remember, don't work on your bike so much you never ride it.
- badrhino
Re: Removing Coils
15 Sep 2012 01:17OldSchoolZ wrote: For asking that, you should gift me your avatar! :lol: :silly:
LOL, Sorry I had a blonde moment.
Franken Z!
Franken Z!
