78 KZ1000A2 Indicator Panel Harness
  • kwaker
  • kwaker's Avatar Topic Author
09 Sep 2012 21:08
#547690
So the horn is not working on my 78 KZ1000A2 - turns out to be that the painted clubman bars could not make ground. Scraping off a little bit of paint under the switch housing and the handle bar clamps fixed the problem. Now that my horn is honking my left indicator is blinking dim together with my headlight. I determined that I have a short in the wiring harness. Systematically tracing down the short, I found it in somewhere in the instrument cluster. Does anybody know where I could find the wiring harness for the instrument cluster (I assume there is a separate indicator panel harness).
Is there an aftermarket solution for this, or where could I find a working replacement for the indicator panel harness??
Any help is greatly appreciated!
1980 KZ 1000 LTD (daily driver)
1978 KZ1000 (project)
Scottsdale, AZ
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
Re: 78 KZ1000A2 Indicator Panel Harness
09 Sep 2012 21:16
#547692
So this is why my horn dosent work???? who knew...I have black painted bars....LOL
  • kwaker
09 Sep 2012 21:21
#547696
Yep, stock handlebars were chrome....
Scottsdale, AZ
  • wireman
  • wireman's Avatar
09 Sep 2012 22:04
#547712
I would bet that harness is the same on a lot of 650/750/900/1000 bikes up till 1980 B)
  • MFolks
  • MFolks's Avatar
09 Sep 2012 22:37
#547725
