Monitoring Charging volts
- wcysl
08 Sep 2012 09:12
I have looked for posts regarding this and have found nothing.
But I have been thinking of mounting a volt meter on my bike to see what the charging system is doing while driving.
I also want to buy something that I can take from easily from one bike to another.
This is what I came up with..
Mount a 12 volt power outlet, wire directly to the battery (Fused) connection.
This >>> 12v outlet
Or something like it? Buy one for each of my bikes.
Then head to the RV store and buy this>>> Volt Meter
Ok is there an easier way? Remember it has to be able to switch bikes.
Has anyone done anything like this?
With the plug-in style meter I have in the link, maybe I can hide the outlet and it would not have to be on the handlebars?
Thoughts? And thanks in advance!
This >>> 12v outlet
Ahh the sound of a socket wrench late at night. haha..
1979 KZ1000 B3
1978 KZ650 C2 $500 Barn find!
1978 KZ400 B1 Free, Saved from scrap!
1979 KZ1000 B3
- P21
Re: Monitoring Charging volts
08 Sep 2012 09:20
that sound good
i have a real old meter that how you would check system if you had no (good) meter
Kawasaki KZ 1000 Police (2002) P21
- wcysl
08 Sep 2012 10:11
Well I want to be able to see what the system is doing will riding.
I just wondered if anyone has done something like this?
I figure I will see a voltage miss through the rpm's if any? Or any odd voltage drop may be noticed?
1979 KZ1000 B3
1979 KZ1000 B3
- OldSchoolZ
08 Sep 2012 11:10 - 08 Sep 2012 11:11
I'd go with something like this.
sell.lulusoso.com/selling-leads/826274/m...eter-waterproof.html
Use a simple quick connect, dont use a cigarette lighter plug, thats just gaudy. :) For 5- 6 dollars each, I would get one for each bike...waterproof also.
Remember, don't work on your bike so much you never ride it.
Last edit: 08 Sep 2012 11:11 by OldSchoolZ.
- wcysl
08 Sep 2012 12:30
OldSchool,
I agree! I would like to have something that does not jump out at you.
But I need something that would not ship direct from China.
I will keep looking. Something small, but easy to read.
1979 KZ1000 B3
1979 KZ1000 B3
- BlackZ1R
- Kawasaki in my blood
10 Sep 2012 00:56
Yup, good questions and a good idea. I had a GPS that had a volt meter in it. It was helpful when running electric riding gear.
KZs aren't strong chargers, especially at idle, so keep the idle at least 1250 RPM.
I would run something like the quick disconnect from a battery tender and a digital volt meter. Here is a couple links.
www.amazon.com/Battery-Tender-081-0148-1...y+tender+accessories
Cut it and terminate one end like this for the battery terminals, or just buy two of these and use one for the volt meter end without the fuse. Then use it with a battery tender to keep your battery up to snuff when your bikes in the garage.
www.amazon.com/Battery-Tender-081-0069-6...y+tender+accessories
www.fcbelectronicsusa.com/servlet/the-11...-dsh-50v-BLUE/Detail
You might can find something smaller and less money. It was the first thing that popped up. It says USA on it.
Kawasaki
Someone once told me to marry that motorcycle I was riding ......there's times I wish I hadda listened .
- MFolks
10 Sep 2012 01:13
Maybe something like this:
www.jpcycles.com/product/350-082?utm_sou...-SqrICFeJgTAod0VkAjQ They come in Black too.
