Adding aux power
  • Topper
  • Topper's Avatar Topic Author
Adding aux power
03 Sep 2012 12:24
#546365
So I bought a BikeMaster 12V cig lighter/aux power thingy. It didn't come with any instructions. I hooked it up with an inline fuse coming directly off the positive battery terminal, and ran the other wire directly to the negative battery terminal.
Plugged my car charger and phone in and I got nothing.
What am I missing here? It seems like this should be pretty straight forward. In the car you plug them into the cig lighter and the charger lights up and the phone indicates it's charging.
Do I need something more than just a direct connect to the battery?
Thanks.
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
  • Motor Head
  • Motor Head's Avatar
Re: Adding aux power
03 Sep 2012 12:32
#546368
Correct, that should work. Check your connections, use a meter to see if 12v is on the center pin of the socket, and ground on the outside spade terminal.
  • mtbspeedfreak
  • mtbspeedfreak's Avatar
03 Sep 2012 12:46
#546371
Is there a fuse in the holder?
2000 ZRX 1100
1976 KZ 900- Daily Driver
  • Topper
03 Sep 2012 15:15
#546406
mtbspeedfreak wrote: Is there a fuse in the holder?
Yes. Though that's exactly the kind of thing I'd do.
I went out with the multimeter and I've got 12.5v at the battery terminals, my bullet connectors and inside the cig lighter connector.
So I took my car charger adapter back to my car and plugged it in. Found the problem. The adapter itself is broken. It was working yesterday when I took it out of the car!
Oh well. That's an easy problem to solve.
Thanks for the help guys. I figured this had to be an easy hook up, but was afraid I was missing something.
1979 KZ750 Twin
  • Motor Head
03 Sep 2012 15:20 - 03 Sep 2012 15:24
#546409
the Adapter will also have a fuse inside, most likely. So look there first.
www.google.com/url?sa=t&rct=j&q=car%20ch...A3QgbbNGMdxkWSBZgBkQ
Last edit: 03 Sep 2012 15:24 by Motor Head.
  • Topper
03 Sep 2012 15:39
#546412
That's a great suggestion. My adapter doesn't screw apart like that, but maybe if I crack the case open I'll find a fuse in there. Can't break what's already broken.
1979 KZ750 Twin
