Found a mystery fusebox!
- ironslave
- sup
02 Sep 2012 20:29 - 03 Sep 2012 14:29
81 KZ750H
so I just got some welding done and while my battery was out I found this thing in the open space behind it. anyone know that it should be use for?
It has a couple of fuses inside the box and a spare fuse on the rubber thing around the fuse box. only one of the three wires are hooked up and it looks like the red and white wire should go to the battery. I have no electrical issues other then lack of a working horn, the neutral light and automatic turn signals not turning off. I figure these are the control box on the handle bar not working and a faulty neutral switch.
Attachment photo.JPG not found
1981 KZ750 LTD
Last edit: 03 Sep 2012 14:29 by ironslave.
- MFolks
Re: Found a mystery fusebox!
02 Sep 2012 20:55
Most Kawasaki's of that age, have/had aux fuses for heated vests or gloves. It should show up on your bikes wiring diagram. Some may be electrically "hot" when the ignition switch is on, so if you want to keep the circuit, get some heatshrink tubing about 1 1/2" long, slide it almost 3/4 of the way on, heat it up, and while it's hot, pinch the end with a pair of pliers.
This will seal the end, but still make it removable if you decide to use heated gloves or vest in the future.
- BRABBIT04161991
02 Sep 2012 22:20
The white blue runs to your hazard relay and also your horn. explains why your turn signals don't go off and why your horn doesn't work. the white black wire isn't needed unless your running a siren lol.
I don't know much but I've been studying the wiring diagram for the past month rewiring my bike
- BRABBIT04161991
02 Sep 2012 22:21
i take that back, it doesn't run to your horn
- ironslave
- sup
03 Sep 2012 14:25BRABBIT04161991 wrote: The white blue runs to your hazard relay and also your horn. explains why your turn signals don't go off and why your horn doesn't work. the white black wire isn't needed unless your running a siren lol.
so this should run hazards when the bike is off and also enable the automatic turn signals to work properly?
1981 KZ750 LTD
- Motor Head
03 Sep 2012 14:34
Look in "File Base" for your wiring diagram, if it is the H2 then this one;
www.kzrider.com/filebase/doc_download/295-z750h2
If the E2 then this one; www.kzrider.com/filebase/doc_download/294-z750e2
