81 kz550 ltd starter problems
  • shockman54
  • shockman54's Avatar Topic Author
30 Aug 2012 19:40
#545736
the starter button is out on my bike, i know the starter itself works, because when i ground it out on the frame, the bike starts right up. any ideas?
  • MFolks
  • MFolks's Avatar
Re: 81 kz550 ltd starter problems
30 Aug 2012 19:46
#545738
Open up the right handlebar switch assembly(it's got 2 halves), look for broken or failed solder joints on the switch contacts. Sometimes a squirt of electrical contact cleaner will get it going again. Do not use WD-40 for this as it later form a non conductive film, preventing the start button from working.
  • MFolks
  • MFolks's Avatar
30 Aug 2012 19:48
#545739
An expanded version of my previous posting:
Starter Solenoid/Motor Checkout Procedure
Some simple steps to determine what is working and what's not:
1.Fully charge and test the battery(most bike shops can load test the battery, and then use a floating ball hydrometer to check specific gravity in the charged cells).
2.Clean all battery terminals of corrosion.
3.Tighten all starting related connections(Positive RED(+) battery terminal, Negative BLACK(-)terminal) and from the terminal to the engine case. All connections must be clean and tight. If the cables feel “Crunchy” when flexed, they may have corrosion inside the insulation, requiring replacement.
4.Clean the cable from the starter solenoid to the starter motor.
5.Clean and check the "bullet connectors" going to the coil side of the starter solenoid.
6.Try again to start the bike, keep in mind some Kawasaki’s have a clutch interlock to prevent cranking the engine while it’s in gear, so the clutch lever must be squeezed.
7.If no luck, go to step #8
8.Wearing eye protection, bridge with pliers or a screwdriver the two heavy duty(large)terminals on the solenoid. If the bike cranks, your solenoid may be bad.
9. If the starter won’t turn over, one of several things has happened; The starter motor has seized due to brushes binding up, lack of lubrication in the bushings of the motor, the battery is weak , the engine has seized or it could be a combination of any of the above. A website for starter motors is:
A. www.psep.biz/store/mitsuba_starter_motors_page_2.htm
B. www.nationsautoelectric.com/Kawasaki.html
C. www.whitedogbikes.com/cat--Kawasaki-Star...-Starter-Motors.html
D. www.ricksmotorsportelectrics.com/starters.php
E. www.dbelectrical.com/
F. www.stockers.com/index.php?dt=HS-29 (Mitsuba SM-220 12 volt 0.8KW Starter Motor)
G http://.www.nationsautoelectric.com/Kawasaki.html
H http:// www.dbelectrical.com/
10.The dealer may want $$$ for a new solenoid, but take your old one along and visit the nearest riding lawn mower shop. They have solenoids for about $15 that with a little work will fit. Be aware that the new solenoid from the lawn mower shop may require a ground wire for it to work.
11. I’d recommend upgrading from the existing battery cables to at least 6 gauge welding cables.
They are available in two colors(RED and BLACK) have more flexibility due to being constructed with finer conductors, and will fit in tighter areas.
12. The welding cable is sold by the foot, so take careful measurements or bring your old cables along. Most battery shops might be able to supply the cable too, so call to find out. The battery shop should be able to crimp/swage on the end of the welding cable the terminal ends or lugs using either a dedicated crimping machine or a tool that looks like a bolt cutter that has special dies to terminate the cable.
  • shockman54
01 Sep 2012 16:18
#546073
i was wondering if anyone has done a push button start on the side of the bike. could i do something as simple as a button on the side that just completes the circuit to ground the starter?
  • OldSchoolZ
  • OldSchoolZ's Avatar
01 Sep 2012 21:23
#546116
You can, but keep in mind, if you bypass every problem you run into, your bike will sooner or later be deemed "rigged" ;)
Remember, don't work on your bike so much you never ride it.
