points plate
- silentchris
points plate
29 Aug 2012 21:47
the previos owner stripped out two of the three screws that my points over the advancer. has anyone else ever drilled them out? How short are these screws?
Speed is only a question of money. How fast do you wanna go?
1978 kz1000 ltd
Hailing from the wild suburbs of our nations capital
1978 kz1000 ltd
Re: points plate
29 Aug 2012 22:25:huh: Would this involve possibility of re-tapping a stripped hole, or removing a screw that broke off inside the hole?silentchris wrote: the previos owner stripped out two of the three screws that my points over the advancer. has anyone else ever drilled them out? How short are these screws?
The following user(s) said Thank You: silentchris
- bountyhunter
Re: points plate
30 Aug 2012 09:21
I think I have a few extra plates in my parts box. Let me know if needed. Cover shipping and they are yours.
- silentchris
Re: points plate
30 Aug 2012 09:21
hopefully no broken screws and no re-threading. I pulled the cover off and once again found myself cursing the PO. Between the carb issues brake issues the front suspension problems im really questioning how that guy could even breath without taking five seconds to think about it.
1978 kz1000 ltd
1978 kz1000 ltd
- silentchris
Re: points plate
30 Aug 2012 09:22
Thanks street fighter the plate should be fine. The screws that hold it down not so much they even look brand new.
1978 kz1000 ltd
1978 kz1000 ltd
- Motor Head
Re: points plate
30 Aug 2012 09:54 - 30 Aug 2012 09:55
4x8mm, so 8mm long. These are JIS not a Phillips, so if the PO used a Phillips he probably damaged the cross slot. You can drill with a left hand bit, and reversible drill. Probably come right out. Then either buy new screws from Kaw, or go to a ACE or other Hardware store. They probably have a few choices, Allen head/ (socket cap screws) would be a good choice.
Last edit: 30 Aug 2012 09:55 by Motor Head.
- silentchris
Re: points plate
30 Aug 2012 10:21
socket cap screws are my preferred replacement. PO put normal Philips heads in there then over tightened them and at some point he tried to take them off again. probably for the same reason i need to. i use a cheap set of jis drivers and have only stripped one screw and that was on my carbs the head was pure corrosion. Ill be bringing home my easy out kit drill and carbide steel bits. Its always nice to know my bits go through ballistic high carbon steel like butter so these screws should be like drilling air.
1978 kz1000 ltd
1978 kz1000 ltd
- silentchris
Re: points plate
30 Aug 2012 20:15
problem solved idle still sticks and takes a second to come down but at least the advancer is lubed and its not jumping up to three when i let out
1978 kz1000 ltd
1978 kz1000 ltd
