Speedometer
  • jasonwebb
  • jasonwebb's Avatar Topic Author
Speedometer
28 Aug 2012 18:54
#545339
My KZ1100 D2 has an electronic speedometer that isn't working. The tach and all gauge lights work fine but not the speedo, odometer, or trip meter. The speedo just kind of randomly bounces. I have a leaky fork seal on the left hand side that may have shorted the sender out? And the wire coming from the sender has been pinched but the wires seem intact. How picky are these wires? Might it be possible to cut them and put new bullet connectors at least as a temporary fix?
If the temporary mickey mouse fix doesn't get things running, anybody have an idea where I might look? As far as I know I'm breaking land speed records all day long here.
Thanks in advance!
Jason
'83 Kawasaki KZ1100 Spectre
'74 Yamaha TX500a
  • Motor Head
  • Motor Head's Avatar
Re: Speedometer
28 Aug 2012 23:23
#545378
Use the link in my signature for a pdf file for the KZ1000/ 1100 with the electric speedo's. There will be tests for the distance sensor on the front wheel/ hub, as well as the electrical circuits.
  • jasonwebb
Re: Speedometer
29 Aug 2012 10:49
#545447
Thanks Mr Head, for helping with both my issues so far :)
I downloaded the shop manual and I'm going to take a look at it this morning.
Jason
'74 Yamaha TX500a
  • whitbyrudie
  • whitbyrudie's Avatar
Re: Speedometer
14 Oct 2012 20:33
#553855
Hey Jason,
Did you have any luck with this?
I've got an 81 kz1000 CSR with the same problem (speedometer, odometer and trip don't work, no leaky forks though)
I've got the pdf manual but haven't had much luck sourcing the problem. If you did get it fixed, have any tips you could pass on?
Cheers
Chris
81 KZ1000 CSR
Vancouver Canada
