Starter worked fine when I parked it last season..
  • Sandy
  • Sandy's Avatar Topic Author
  • Fly High,Tony
24 Aug 2012 13:24
#544502
Fully charged battery,all connections are tight,bike was NOT stored outside,it's been in a heated garage.Charging system is fine,battery reads over 12 volts,sitting.All other electrical works perfectly.
Now,all of a sudden(this year),it decides to not turn the engine over.(It does,but barely).
I had NO signs of it failing last season.
I know with my engine mods,it's making the starter work,that's a given...but why all of a sudden? :huh:
Is the bike pissed at me for not taking it out sooner this season? :dry:
1977 KZ1000 A-1
  • Motor Head
  • Motor Head's Avatar
Re: Starter worked fine when I parked it last season..
24 Aug 2012 13:33 - 24 Aug 2012 13:33
#544504
Suspect the battery. Check the battery voltage when attempting to crank. try jumping from a NON running Car/ battery. More than Likely a Bad Battery.
Last edit: 24 Aug 2012 13:33 by Motor Head.
  • Sandy
  • Fly High,Tony
24 Aug 2012 13:40
#544507
Motor Head wrote: Suspect the battery. Check the battery voltage when attempting to crank. try jumping from a NON running Car/ battery. More than Likely a Bad Battery.
Ya,good call Motor head.
Although the battery has been kept up all this time(and it's only a year old),I have had problems with this particular brand before.(Motomaster from Canadian Tire).
I've got a deep-cycle battery here,I'll try that when I get a chance,later today.
Thanks a lot for your input,Bud...that COULD be the problem.
1977 KZ1000 A-1
  • Motor Head
24 Aug 2012 13:42 - 24 Aug 2012 13:43
#544510
Is that a AGM (Absorbed Glass Mat) or a normal Wet Cell? if a Wet Cell, have you checked the level in it? If kept continuously on a charger it may be low on electrolyte.
Last edit: 24 Aug 2012 13:43 by Motor Head.
  • Sandy
  • Fly High,Tony
24 Aug 2012 16:33
#544543
Wet cell,sealed unit.You buy it as a kit,add the electrolyte,fit the sealed rubber cap into place and done.No vent-tube.
I'm about to jump it from another battery and see if that works...
1977 KZ1000 A-1
  • Sandy
  • Fly High,Tony
24 Aug 2012 16:50
#544548
Bingo...it IS the battery,frikken piece of shhhhh.
I'm shocked,cause that battery just went in last season and like I said,it's been maintained the entire time.
Thanks Motor Head!
1977 KZ1000 A-1
  • bountyhunter
  • bountyhunter's Avatar
24 Aug 2012 21:39
#544610
Make sure the battery tender is a good one that is temperature compensated so it will not boil it dry in hot weather.
  • Old Man Rock
  • Old Man Rock's Avatar
26 Aug 2012 08:37
#544827
"battery,frikken piece of shhhhh.".... :laugh: :laugh: :laugh:
Hey Sandy, you live... Sure, only drop in when you need help.... :S :P :laugh:
AGM batteries, only way to go... My first one lasted almost 4 years and that's here in AZ Heat (Hell)...
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • Sandy
  • Fly High,Tony
27 Aug 2012 12:22
#545043
HA HA,Rock!
No...haven't been riding(went for a good haul this weekend though)...been riding my quad a lot,havin an absolute blast with it.
Ya,I'm going to look into a good battery for the Kawi,cause that's b.s.
Bountyhunter,it's not an actual,"Tender",it's a 1 amp trickle-charger that I plug in about once a month to top it off.
Went for about a 300km ride on Saturday,the Kawi ran like a champ!
1977 KZ1000 A-1
