1980 kz1000 right handlebar switch
- 78craft
21 Aug 2012 21:55
Has anyone rebuild the starter button on one of these? My starter button fell out. I have the button and I also have a spring but I can not figure out how it goes back together. I am guessing the button portion is cracked as only a small portion of it has a lip.
Any ideas?
Any ideas?
- pete greek1
Re: 1980 kz1000 right handlebar switch
21 Aug 2012 23:17
get a new one from Z1 enterprize,... probably less than $45.00... then no more problems with that switch ....Pete
- MFolks
21 Aug 2012 23:23
The switch is pretty simple, a spring for retraction when the button is released, & a phenolic or insulated part holding the electrical contacts, and that's it. When the start button is pushed, the contacts are made, sending the voltage/current to the pull in coil on the starter solenoid.
- pete greek1
21 Aug 2012 23:33
you can try Mfolks suggestion first, its free, & it wont cost you a dime, if you see that there is a problem with the button being cracked, you can probably get a new one for the same price of a used one on flea bay
- DiamondSkyBlue1000
- 78craft
22 Aug 2012 21:52
one would think that shoving just the button in to make contact would get it to turn over. It does nothing.....
- MFolks
22 Aug 2012 21:58
Opened up the switch housing? Possibly a broken solder joint is causing the problem, as the older bikes are having failed or crumbled solder joints.
- fordtruck
23 Aug 2012 02:42
My button on my 77 did the same thing. I ordered just the button from Redline Cycles. It's kind of a pain to install it, but much cheaper than a whole switch assembly.
'77 KZ1000-MTC 1075 kit. Stage 1 port
