UMO (unidentified motorcycle object)
  • DELAHUNT875
  • DELAHUNT875's Avatar Topic Author
19 Aug 2012 19:51
#543469
1981kz550a2 Can someone tell me what the hell is this thing is umo (unidentified motorcycle object)
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
Re: UMO (unidentified motorcycle object)
19 Aug 2012 19:59 - 19 Aug 2012 20:03
#543473
Light Checker (tail-light) 3 wire connector.... tells you that the taillight is out by lighting the red light on gauge panel....my says (stop lamp)
Last edit: 19 Aug 2012 20:03 by 4TheKZ1000.
  • DELAHUNT875
19 Aug 2012 20:11
#543476
Thank you!! Do u know where the starter disconnect switch is or what it may look like?
  • MFolks
  • MFolks's Avatar
19 Aug 2012 20:37
#543478
The starter interlock switch? If that's what you're after, most are on the clutch lever mount, a small,spring loaded switch that pops out when the clutch lever is squeezed, closing the contacts & permitting the start button to work.
The wiring goes from the clutch mount, and then to the headlight housing.
19 Aug 2012 21:35
#543491
The following link is to a downloadable wiring diagram in KZrider's FILEBASE:
www.kzrider.com/filebase/doc_download/301-z550a2
Attachment filebasekzr.jpg not found
Good Fortune! :)
  • DELAHUNT875
19 Aug 2012 21:57
#543495
This is a copy of what i have but my lever dont have any wires on it
  • DiamondSkyBlue1000
  • DiamondSkyBlue1000's Avatar
19 Aug 2012 22:18
#543501
That's your kickstand interlock switch. It keeps you from starting the bike in gear with the kickstand down.
Please try to avoid sending .doc files. They are notoriously dangerous to open because they can contain viruses and what have you.
The following user(s) said Thank You: elfmagic17
