Radiator Fan Stopped Working
  • BLSSeattle
  • BLSSeattle's Avatar Topic Author
18 Aug 2012 16:37
#543281
Hi all. Any quick ideas where I should look first? I don't know if there are known issues with any one link in the chain. Thanks for any help.
Re: Radiator Fan Stopped Working
18 Aug 2012 17:48
#543294
  • OldSchoolZ
  • OldSchoolZ's Avatar
18 Aug 2012 19:31
#543315
More times than not on an older Z, its the radiator fan switch. This sensor is mounted on the radiator and when it reaches a certain temp, it connects the 2 internal wires and connects the fans power to run. These switches often get corroded or simply create an open circuit. Easy test, find your radiator fan switch, some have 2 wires which connect together to turn on fan and others have only one wire which can be grounded to complete the fan circuit. By jumping the wires and bypassing fan switch, you can see if the switch is bad or if the fan is bad.
Remember, don't work on your bike so much you never ride it.
  • wireman
  • wireman's Avatar
18 Aug 2012 20:04
#543318
What kind of bike are you working on?
Id check for a thermostat or a relay to make sure youre getting power to the fan itself B)
  • OldSchoolZ
19 Aug 2012 14:01
#543424
If the fan switch is a 2 wire, it is most likely connecting 2 hots and you wouldnt see power at your fan until this switch reached temperature. Jump your switch with key on, if fan spins, its switch, if it doesnt, I would suspect another problem which will be less likely.
  • badrhino
  • badrhino's Avatar
19 Aug 2012 15:12
#543432
Umm when did KZ's get fans? lol
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
  • badrhino
  • badrhino's Avatar
19 Aug 2012 15:13
#543433
Oh, and thanks for stealing my avatar!
Franken Z!
  • martin_csr
  • martin_csr's Avatar
19 Aug 2012 15:53 - 22 Jan 2013 21:13
#543438
never mind
Last edit: 22 Jan 2013 21:13 by martin_csr.
  • OldSchoolZ
20 Aug 2012 15:33
#543658
badrhino wrote: Oh, and thanks for stealing my avatar!
:laugh: Ive had this pic on my PC for a long time, I had no idea anyone else was using it. Fairs fair, you were her first, I'll change it.
P.S. There are water cooled KZ's
  • steell
  • steell's Avatar
21 Aug 2012 16:47
#543936
badrhino wrote: Umm when did KZ's get fans? lol
Like the post above said, KZ1300 water cooled six cylinder inline KZ with a radiator fan :P
