What wiring can go?
- petesmith999
What wiring can go?
18 Aug 2012 11:15
Hi all, what a great forum this is, I've already sorted loads of problems thanks to all on here. Today I fitted a DynaS ignition as my poor old LTD 750's pick ups were shot. All went well and she's running again. Now this is a bobber project so I am looking at removing the indicators and all the wiring as well as anything else unused. Most of its corroded anyway. What I wondered is can I now remove the igniter as the DynaS bypasses it, and are there any other bits I can lose, or is it easier to rewire? Has anyone done a rewire with just the basics, lights,horn,starter etc? Any tips appreciated.
Cheers
Peter
Cheers
Peter
- wireman
Re: What wiring can go?
18 Aug 2012 13:27
Its pretty simple just remove whats not hooked to anything after you get it running.
sounds like you just need a charging system/headlight/tail light and a brake light,ditching handlebar stuff cuts lots of wiring out of system
- petesmith999
18 Aug 2012 15:01
Thanks wireman, that's what I thought, just remove a bit at a time and check everything still works. Did a car years ago but this is my first bike build, had loads but never built a whole one.looks like there's lots not needed.
18 Aug 2012 17:56 - 18 Aug 2012 17:57petesmith999 wrote: ...fitted a DynaS ignition as my poor old LTD 750's pick ups were shot...can I now remove the igniter as the DynaS bypasses it....
The stock ignition coils probably have lower resistance than the 3 ohms needed by the Dyna-S ignition, which lower resistance could result in parts failure.
Yes, the igniter may now be removed as it is no longer needed with the Dyna-S ignition.
Last edit: 18 Aug 2012 17:57 by Patton.
