1980 KZ1000 Classic Fuel Injectors
  • Z Parts
  • Z Parts's Avatar Topic Author
14 Aug 2012 22:30
#542661
What is the actual head size of the bolts that hold the injectors in. I think someone has tried to take out before and used the wrong size tool.
  • MFolks
  • MFolks's Avatar
Re: 1980 KZ1000 Classic Fuel Injectors
14 Aug 2012 22:35
#542665
I doubt they are 6mm, probably 5mm or 4mm. Did someone try using the wrong size Allen wrench?
  • Z Parts
14 Aug 2012 23:37
#542687
I think they did and I don1t want to damage the bolt any more then it is. They are really tight so I don`t want to make it worse.
  • MFolks
  • MFolks's Avatar
15 Aug 2012 00:02
#542695
If possible,get some Kroil and soak the injector screws before trying to loosen them.
