82 1000 starter
- Buda
14 Aug 2012 16:54 #542595
by Buda
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
82 1000 starter was created by Buda
Will not turn the engine over....10.25 10 1 comp 1170 cc......took starter out and ran it with a battery....the starter spins strong but starts to squeal after a second.....also the shaft has alot of play side to side. Bad starter im guessin. What do you guys think?
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
- Buda
14 Aug 2012 18:23 #542608
by Buda
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Replied by Buda on topic 82 1000 starter
Took the starter apart.....the bushing on the drive end is cracked
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
- MFolks
- Thank you received: 540
14 Aug 2012 18:39 #542613
by MFolks
Replied by MFolks on topic 82 1000 starter
For a stonger starter motor, read this:
Using a Honda Mitsuba SM-220 Starter in the Kz (copied from the KZ rider website)
The CB F's used 2 different starters. Look for the one marked .8kw. They also have one that is .7kw. This owner noticed a difference when he installed his. He read that you can remove the outer housing, and rotate it. this will re-align the outer power terminal, to a better location. if you don’t do this, you will need to grind some metal from the chain cover to gain clearance. Also install a heavier gauge wire to the starter , I’d recommend 6 AWG(American Wire Gauge) welding cable with the correct terminal ends to match the treaded studs for the solenoid and starter motor. Don’t forget the cable from the battery to the solenoid.
The stock KZ starter is .6kw in size
www.stockers.com/index.php?dt=HS-29 (Mitsuba SM-220)
- Buda
14 Aug 2012 19:15 #542621
by Buda
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Thanks M.....Just ordered the rebuild kit before I read your post....If that doesn't work out I'll give the honda starter a shot.
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
- Buda
04 Sep 2012 23:10 #546715
by Buda
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Replied by Buda on topic 82 1000 starter ....replace with the honda .8
Got a the Honda starter MFolks recommended (SM 220 12 volt 0.8 KW) on ebay...hell of a difference.....Turns over like the plugs are missing....I'm sure the new battery doesn't hurt but its a hell of a difference.
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
- MFolks
04 Sep 2012 23:37 #546724
by MFolks
Replied by MFolks on topic 82 1000 starter ....replace with the honda .8
I'll bet the engine just needs a slight tap of the starter button to fire up...
