rewired my fuses and found this HOLY CRACK!!!!
- pocycle
11 Aug 2012 23:37
I rewired my fuses under the seatto blade style and was checking around for obvious things that could be addressed....So I noticed the gap on one side of the piece in the picture was larger than the other so of course I figured I would tighten it.... bad idea!!! CRACK!!!! How screwed am I.... anyone?
- MFolks
Re: rewired my fuses and found this HOLY CRACK!!!!
11 Aug 2012 23:59
Go to
www.kzzone.com/billet.html
and order their block off plates. Then remove all of the "Smog Gear"(vacuum lines,a rubber hose from the air box to the air valve control switch & other not needed lines).
It's a system designed to reduce emissions, called the Kawasaki clean air suction system(KCASS)that neither adds or reduces horsepower to the engine.
The factory shop manuals mention it, and how to maintain it.
- pocycle
12 Aug 2012 00:33
dude you rock.... I cant tell you how much I've learned just reading all the posts; very helpful. Ordering 1 tonight!!! As you can see in the pictures I'm havin a blast with this bike, learning to love her.
- MFolks
12 Aug 2012 01:04
If you don't have this, copy/bookmark if possible the web pages:
en.wikipedia.org/wiki/Kawasaki_police_motorcycles
dot.com.ph/uncle/kz1000cop.html
www.cyclepsycho.com/kz1000p/kz1000p.html (wiring diagrams, for when you decide to remove un needed wiring).
- keithnra
15 Aug 2012 09:02
do u have any pages for a 78 KZ1000 LTD B2 model like this
