Ignition Switch Replacement
  • Spitfire151
  • Spitfire151's Avatar Topic Author
11 Aug 2012 14:41
#541953
I've decided I'd like to relocate my ignition switch for my 1981 kz440b2 and in looking over the internet, I can only seem to find switch with three posts for wiring... or replacement mini switches that are only listed as fitting Hondas of the same era. I want to do away with the fork lock and the amount that the stem of the switch shows above my triple tree.
Ideas?
  • dejavoodo41
  • dejavoodo41's Avatar
Re: Ignition Switch Replacement
11 Aug 2012 15:44 - 11 Aug 2012 15:46
#541959
1977 KZ1000A With 1980 KZ1000A MKII engine, Wiseco 1105 kit, Dyna S Ignition, 3 Ohm Dyna Coils, Cams, Mikuni RS34 Carbs, Vance and Hines Pro Pipe with Comp Baffle
New Smyrna Beach, FL
Last edit: 11 Aug 2012 15:46 by dejavoodo41.
  • Spitfire151
11 Aug 2012 15:54
#541960
Gotcha, but how did you wire it up?
  • tjgonz
  • tjgonz's Avatar
11 Aug 2012 16:55 - 11 Aug 2012 16:57
#541963
I used this cheapo one from ebay on a panel inside my tank facing me.
Universal Keyed Ignition
I had first just used a racing toggle switch. It's very easy just strip wires & touch them until you find a combination that works or buy one that comes with a wiring diagram.
Last edit: 11 Aug 2012 16:57 by tjgonz.
  • dejavoodo41
11 Aug 2012 17:26
#541967
I run a very minimalist system and basically made my own wire harness with just a lighting circuit and a ignition circuit. I don't have any turn signals, horn or anything else so I really can't tell you how it would wire into your system not to mention it was 4 years ago so I really don't remember how I did it.
  • Spitfire151
12 Aug 2012 17:01 - 13 Aug 2012 19:57
#542128
Ohhh okay, well looks like I've got my work cut out for me, unless this thing matches up perfectly that is.
Last edit: 13 Aug 2012 19:57 by Spitfire151.
