No running lights.
  • Eddyv54
  • Eddyv54's Avatar Topic Author
No running lights.
10 Aug 2012 01:24
#541680
Hello.
Info: 1978 Kz650 B2
Bike runs great.
I have no running lights. That is to say, the headlight and the tail light don't do anything when switching to lights-> on. I have a brake light, and I have a Park Light, but not running lights.
Now, I'm not sure if I need a complete circuit in the front (switched out the turn front turn signals to single filliment turn signals).
I also switched out the fuse box to blade fuses. All fuses intact. Checked circuit completeness with a meter, however it could be a wire that was not all the way inserted in the new housing? Does one of the two 10amp fuses control the running lights?
I can ride the bike around, the turn signals work, but no headlight/tail light.
I had a working lights BEFORE I switched to a chrome bucket. I had an ugly fairing on there which was taken off.
I'm sure it's something small that I missed. Are the blue running lights supposed to be a complete circuit somewhere?
Thanks.
  • MFolks
  • MFolks's Avatar
Re: No running lights.
10 Aug 2012 01:32
#541682
LEFT FRONT TURN SIGNAL Can be an #1157 dual filament bulb
GREEN, Left front turn signal circuit.
BLUE, Left front running light circuit.
BLACK with YELLOW stripe, the ground circuit.
RIGHT FRONT TURN SIGNAL Can be an # 1157 dual filament bulb
GREY, Right front turn signal circuit.
BLUE, Right front running light circuit.
HEADLIGHT
RED with BLACK stripe, High Beam.
RED with YELLOW stripe, Low Beam.
BRAKE/TAIL LIGHT Can be an # 1157 dual filament bulb
RED, Running or Tail Light.
BLUE,(sometimes with a Red stripe) Brake Light Circuit.
LEFT REAR TURN SIGNAL Can be an #1156 single filament bulb
GREEN, Left rear turn signal circuit.
RIGHT REAR TURN SIGNAL Can be an #1156 single filament bulb
GREY, Right rear turn signal circuit.
